D
**DONOTDELETE**
Guest
Hello everybody.
I recently installed a Mag charger in my car. Unfortunately I today discovered that the car battery was (almost) drained and I had to charge it to start the car. I would imagine that the flashlight was the culprit and thought I´d check if someone has any experience with this. What is the best configuration for installing these lights, should you wire it for constant charge or just for charging with the ignition turned on, does it draw enough current to discharge the car battery even when the flashlight is fully charged, does ignition-only charge suffice for keeping it charged?
I guess it comes down to how much/little I use the car/flashlight in the end, however any ideas on installation/wiring are welcome.
