XTAR new flashlight D26 1600, which perfect partner for your diving and fishing!!
XTAR Light
Vendor
China
Scuba diving underwater torches and dive lights can be vital, especially when deep diving or cave diving. As you get further below the water's surface your surroundings become dark due to the depth you are at. A diving torch allows you to see exactly what lies ahead of you when your eyes fail to do so. Crucial in certain dive situations such as diving expeditions without natural light, a dive torch could be the only source to allow you to see your surroundings and help avoid any unwanted accidents when in unfamiliar territories.
Dive lights also come in handy when you need to check your compass or another un-illuminated piece of important equipment. Scuba diving torches can also be used to communicate between buddies and get there attention while exploring the ocean's depths.
We strongly recommend you take a dive light along with you on every dive you undertake. Even if it is just a tropical daytime dive, most experienced divers will have a small pocket torch which allows them to shine it either in a nook or overhang at certain fishes bringing their colours alive!
Max 1600Lm output, perfect choice for your diving and fishing, Applied with Cree XHP35-HI D4 LED, this flashlight has high light efficiency and mighty long shot capacity. Glass Lens Ultra-clear Tempered Glass Lens with Anti-reflective Coating. Transmittance up to 98.5%, common glass:89-92% Transmittance. Press once to turn on flashlight. Press again to switch brightness, in order of Turbo, High, Mid and Low. Press for 1.5s to turn off flashlight. Long press 3s shut down flashlight and lock the buttom, the green light will flicker. Press the switch button thrice continuously to unlock and light-up flashlight.
Comes with a battery indicator, keeps you updated of the battery power, ensure your safety on the sea. When the power os 25% above, green light remains on. When the power is about 5%-25%, red light remains on. When less than 5%, red light will flicker to remind you to change battery ASAP, otherwise the battery will be over-discharged.
55°visible angle you a broader view, enables you to see more marine life, which is also much safer when you are fishing and diving.
Wildly available with 1*18650/1*18700/1*26650/2*16340/2*CR123A batteries. 18650&18700 batteries should be used with yhe standard plastic tube.
Support 26650 large-capacity battery. Even with max 1600lm output, this flashlight can also keep working 2.48hrs.
The stand-by current is 750μA. The flashlight with full-power 5200AH 26650 lithium battery can maintain 290 days or so after shutdown.
The front blue rubber ring enhances natural color, more natural and colorful.
Waterproof IPX8(Underwater 100 meters), passed strict test by authorized organization.
➡️Click here to know more: XTAR|Battery&Charger&Flashlight
Business inquiry email: [email protected]
Follow XTAR Facebook page: Shenzhen XTAR Electronics Co., Ltd
Join XTAR Group: XTAR Good Times
