winny
Because so many of people asked for drop-in kits with our PIR 1 regulator, we have decided to make the most deluxe kit you will ever need. It will come with an aluminium switch replacement with a ceramic socket. The regulator itself is built in so you won't have to solder anything this time. Furthermore, it will come with a special battery pack for 4n*AA batteries for unbored Mags using contacts with much lower resistance than the original spring-in-the-tailcap-solution. They will come calibrated from us with your specified settings and reprogramming is done via a USB-interface.
So, what you will get is this:
As always, the regulator can cope with just about any voltage difference (where your battery voltage is higher than your desired bulb voltage) with a sustained >95 % efficiancy.
The only tools you need is a 2 mm hex key and a screwdriver. This mod requires very little modding skills and is totally reversible. You can make your own MR16-mod or a regulated MAG85 if you have a reflector in very short time. Power levels up to 50 W is not a problem and 100 W with some minor modifications.
This is an early version of how it will look. The final design will change...
The price will be about $150, depending on demand. We need about 15 orders to make this work.
- Complete switch replacement in aluminium
- A built-in PIR 1 regulator
- A special battery pack for 8*AA batteries for the 2D model, 12*AA for the 3D, 16*AA for the 4D model
