Angryfox
Results 1 to 8 of 8
Thread: Replacing LEd in Dorcy super 1 watt
    Flashaholic* Aaron1100us's Avatar
    Dec 2005
    Cedar Rapids, Iowa
    Default Replacing LEd in Dorcy super 1 watt
    I just got a Dorcy super 1 watt and took it apart. Is there a 3 or 3+ watt led that could be put in there? Its the 1X123 battery version. Seems pretty easy to do. Thanks
    Surefire G2, M3, E1L, Inova X5 white, X5 blue, X1, AE 24w HID, RR 2XAA, 2XC, 2XAAA , RR incan/led, Dorcy Metal Gear, Brinkman 4 LED, Mini mag, Pelican Mightylite, Coleman lantern, River Rock lantern, Omega shake light, NightStar shake light, Streamlight keymate,inova LED key light, 2 river rock LED key lights, Princton Tec Apex, energizer 6 LED headlamp, RiverRock .5w Headlamp, Streamlight 4XAA Lux, Brinkmann MaxFire, Princeton Tech Rage, 3 Garrity chrome classics, Mag 85, Mag 3D, Thor platinum
    Unenlightened
    Nebraska
    Default Re: Replacing LEd in Dorcy super 1 watt
    I was wondering the same. I orderd a Lux III. well see I guess.
    Flashaholic* WNG's Avatar
    Nov 2004
    Arrid Zone-Ah, USA
    It should be a simple replacement job. The Dorcy pretty much unscrews and the Star is not fastened.
    But swapping a 3W will only yield an underdriven 3W light. The regulator circuit must be modded to supply the necessary amperage to reach 3W operation. I'm assuming you haven't considered this yet.
    How is this accomplished? Change a resistor? Please advise.
    Mar 2006
    Jonesboro, AR
    Quote Originally Posted by Fiddleback
    I'd be interested in this as well. Maybe direct drive it with a rechargeable?
    Unenlightened
    Nebraska
    I figured the circuit needs modding, that shouldnt be hard. I'm still trying to figure out how it comes apart. I assume the black peice just pushes in. ???
    Flashaholic* thezman's Avatar
    Dec 2005
    PA
    The black part on the top of the body is just a press fit.
    It comes out real easy.
    Dec 2005
    PA
    Oh, and then use a dowel through the body, from the bottom, to push out the board and retaining collar.
