thefish
I am working on 2 designs at the same time, I may just produce a short run (say 10) of each of them just to play with, anyway...
Option 1 (good for 1 watt apps)
Voltage Boost
V boost range: 0.9-3.2V
Abs max limit: 6V
Constant Current 350ma (very flat even with 1.2Vin)
At low batt auto drop to 70ma
Up to 90% efficient
Dia: 0.60in
Option 2 (good for high power K2)
Voltage Boost (fixed out at 4.2V)
V range: 0.5V-4.2V (beyond will go DD)
Abs max limit: 5V
Current Output up to 2A <-- Good for K2
Up to 97% efficient (closer vin to 4.2V the higher efficiency)
Dia 0.60in
Option 1 is nice because it is constant current and auto adjusting forward voltage, where as option 2 is fixed at 4.2V output (will overdrive your LED)
Option 2 is nice because it can deliver up to 2 amps and also it allows you to basically use any battery you can find NiMh, Alkaline, Li-Ion, Li Primary, ect, and with a Li-Ion it is 97% efficient. Can be changed into quasi CC by adding resistor to the output (although lowers efficiency).
P.S.
Option 1 is already in design revision 5 and almost ready to go production, option 2 needs more work.
Voltage Boost
Abs max limit: 6V
Up to 90% efficient
Dia: 0.60in
Abs max limit: 5V
Dia 0.60in
P.S.
