<font size="2" face="Verdana, Arial">Vise. Hacksaw. File. Agony.Originally posted by Ben H:
Would like to mount a ls in the body of a D-cell Maglight. What is the best/easiest way to make a heatsink that fits in the top of the Mag body?
<font size="2" face="Verdana, Arial">I have tried that. The problem is that you need to have the disc within .001 to .002 of the size of the flashlight body.Originally posted by Ben H:
Say it ain't so!!!
Vise. Hacksaw (blood). File (sweat). Agony (tears).???? A labor of love or insanity.....I can't decide.
Anybody have any luck cutting aluminum plate with a hole saw?
Thanks,
Ben
<font size="2" face="Verdana, Arial">Oh yeah, I remember those. I have a few of them too. I never really used them though, but I'm sure they work great. Hey, that's where I got the idea from in the first place!Originally posted by lambda:
Ben,
I have some nice round heatsinks for Mag mods. Check out http://lambda10.tripod.com/3dmag.htm for a write up of the mod and pictures of the heatsink.
<font size="2" face="Verdana, Arial">I must say that these sinks that lambda has are wonderful...Originally posted by lambda:
Ben,
<font size="2" face="Verdana, Arial">Until you get a machinest to do the work for you, you could try cutting it with a hack saw. It's not as hard as it sounds. Draw the circle on the aluminun, and then begin cutting off pieces. When you get it close to the size, then you begin to use a metal file to shape the disc. Aluminum is soft and cuts and files quite easily. At first it would take me about 30 minutes, but now I can do it in about 10 to 15 minutes. Chamfer the edge that presses into the flashlight, to help it go in easier.Originally posted by Ben H:
Thanks for all the input! I'm having a local job shop quote some Al discs for me. If the price isn't outrageous I'll get some from them. I tried the hole saw last night....the disc was undersized about 1/16". So close yet so far away.
Lambda: Your heatsinks look great! Do you still want $3 for your heatsinks?
<font size="2" face="Verdana, Arial">Sometimes I make it hear to read also!Originally posted by Bushman:
Ben you would do better to email lambda instead of catching him here... some times he is sooo busy modding that he dosent' always catch every post. Mike
<font size="2" face="Verdana, Arial">Hey Ben,Originally posted by Ben H:
I want to thank you all for your great input. Last night I made my first heatsink out of 1/4" Al!!! It took a LONG time, but the results were better than expected. I used ElektroLumen's recommended tooling: hacksaw, file, and a little Dremel mixed in. I'm thinking this 1/4" heatsink should keep my ls at a very comfortable temp.
Lambda, I'm sending you an email.
<font size="2" face="Verdana, Arial">I make a heat sink which fits on the end, and epoxy it to the body with heat sink epoxy. I use 1/8" thick aluminum. I drill holes through it for the wires, which I push into the electrical contact holes. I epoxy the emitter on, and then solder the wires. A lot of work! With the Lambertian high domes, the stock reflector focuses the light quite well, but the reflector must be modified to work.Originally posted by Ben H:
Hi Wayne,
I took a different approach with my Brinkmann 3 AA mods. I only had a ls on the hex pad, so I rounded off the corners until it fit in the head. I sanded one side of a copper penny smooth and put all that in the head with some thermal compound. I glued the head to the body with some thermal epoxy, and the thing works great.
Did you use a ls emitter with the heatsink attached to the body of the flashlight?
It's a bummer we all aren't neighbors......if we combined all the knowledge, skill, and resources we could have one sweet flashlight company!!!!
I pray your StarLux's go together much faster than my 3D Mag is going to!
Have a great weekend!
Ben
