I think it would work fine, I have used my X0 (old version, now X02) and X03 in that role last year in archery, rifle and muzzleloading seasons. I had no trouble with using them at all. Too floody and bright a beam tends to reflect off every branch with leaves and make it more difficult and also be "intrusive" in the woods. A fellow bow hunter will understand what I mean, it is a feeling and knowledge that everything in the woods knows you are there, instead of being part of the woods. I find the X0 (old version) and X03 have just enough spill to be effective.
Actually, I used my new X1 the other morning out checking a hunting area, and it worked very well. It has a floody beam, but is dim enough that you see just close up and do not intrude on the woods at all.
I may use both the X0 (old version) and X1 this year, using the X0 until I get closer to my area and then switch to the small X1 and its dimmer light.
