Help please. My first build.......
I'm building a space needle using a Lux V (WWOT) on an hotlips heat sink, mag 2D, six AA' s. I plan to use alkaline, which means running at 9V. I'm going to use a 1 ohm resistor to drop the voltage down, so how many watts should the resistor be rated at? At the moment I can only find a 2.5W lying around at work, will that do?
(Yes I know direct drive is not best practice, I plan to get a driver soon)
