RebelXTNC
Another smelly set of flashlights from Home Depot! But they do work and the Chinese rubber smell on these wasn't too overpowering.
These lights use 2xAAA batteries each and have 1 white, 1 yellow and 1 red LED. A four-way switch cycles through the 3 colors and off.
These LED's, especially the white one looks somewhat like the emitter that's in the River Rock 2xAAA light but it's not quite that bright. The triple reflector is similar to the $1 lights that Dollar Tree had a few weeks back, except the Dollar Tree reflectors were much smoother and had fewer artifacts.
The white LED is sufficiently bright for task lighting and general low-level illumination out to 15-20 feet. These lights are pretty large for their batteries and light output, but are comfortable to hold.
The red is fairly intense and makes an artifact-filled spot. The yellow makes a heavily artifacted moderate flood. The white is pretty smooth.
I believe you could remove the AAA tube and mod these lights for AA use but you might have to rework the lower battery contact.
The set comes with 10 Rayovac Maximum Plus alkalines, which I immediately threw away since many of the packs in the store were showing frosty residue or worse and I've seen this many times with this brand.
If you need a 5-pack of cheap rubberized lights with the addition of red and yellow lighting that's dead simple, this is a good candidate. Just don't expect more than task-lighting brightness for the white or night-vision use with yellow or red.
