I know the DBS is a thrower. I was just hoping it was useful for something beyond pure throw, but it doesn't sound like it is. I don't usually go walking with a light, so that was just a hypothetical example.
I still hope someone can deliver comparative beam shots from fairly close range with a Fenix L2D-CE.
I bought my DBS/2SD with both reflectors. I played with it using the SM reflector for a while first, and then switched it to the OP reflector.
In my opinion, the DBS is a MUCH better light with the OP reflector, and I doubt if I'll be going back to the SM reflector again.
Now to a comparison...
No pictures (I'm not using any hosting sites), but I think I can reasonably and accurately describe the difference between my DBS/2SD on high, and my L2D-CD/Q5 on high. (By the way, I did this just for you... so you owe me
At about 20 feet on a flat surface, the L2D's total beam (inc. spill) is about 25% wider than the DBs.
The brightness of the spill area all the way out to the edge of the DBS is significantly brighter than the L2D.
The bright center beam of both lights are virtually the same in width, but the L2D has no "hot spot" in the middle of the center beam while the DBS does (think of the L2D as having a "soft candy nougat" as a center beam while the DBS' center beam is a soft (but brighter) candy nougat with a chewy caramel in the middle
The DBS' center beam is clearly and obviously brighter overall than the center beam of the L2D.
Conclusions (personal):
1. The DBS is at it's best with the OP reflector. Period.
Screw this "throw" nonsense. When you go outside and actually use the DBS to
SEE things, the OP reflector is far superior to the SM reflector.
But, yea, the DBS still "throws" quite well, even with the OP.
2. On "medium", the DBS compares
very closely in overall brightness to the L2D on it's medium setting (as in; low,
medium, high, turbo) except that the center spot of the DBS w/OP is still brighter and smaller than the L2D.
3. As far as "spotlight" is concerned, get a AE Xenide 25W if you want a spotlight
Overall, the DBS w/OP is a very nice "walking light" and is a good compromise between a more floody light like the L2D and a more narrow-beamed light like any of the DBS class lights with SM reflectors (also includes MRV, Tiablo A9, etc.)
At the same time, the DBS w/OP will reach (throw) much further than the L2D if the dog runs away and you need to find him on the other side of the field.
That's my .02
