Yapo
I bought a pair of Protected Ultrafire 2400mah 18650 and a pair of Protected Ultrafire 3.6V 880mah 16340 from DX a few months ago... i tried both 18650's when i got them before charging and 1 seemed dead and didnt make any light from my flashlight...So i charged them both and they seemed to work fine. But then on my 1st full use of 1 of them(i'm not sure which one) i was expecting the protection circuit to kick in when my light got dimmer and dimmer but nothing happened so i checked the voltage of the battery and it was reading 2.8V so i decided not to use it any further as i've heard running lithiums below 3V could damage them.
Anyone know if that is true or if the cut off voltage is meant to be lower?
I've been using my 16340's fine but i recently tried using the pair, which i charged a few weeks ago, in a new flashlight but it wouldnt light it up so i thought there was somthing wrong with the connection in the flashlight but i tried a 18650 in it and it worked fine. I checked the voltage of the 2 16340 cells and 1 was fine at 4V but the other seemed to be unreadable giving me really low voltage that kept on changing...
So should i try charging it again? or would it be best to get new batteries?
Anyone else had these problems with ultrafire cells or even other brands?
