Surefire M2 mounting options
chamenos
Singapore
remove the clip, then use normal scope rings /ubbthreads/images/graemlins/smile.gif
Size15's
Kettering, England
After removing the clip, the SureFire M31 high mount should work I believe.
There are other mounts from other companies. If you are looking to cut corners and go cheap then I suggest you search some firearms forums such as www.AR15.com
Al
Wolfman
Edmonton, Alberta, Canada
The Fobus flashlight mount is cheap enough, I think I'll go with that.
Which clickie tailcap should I get for this? Also, how do you safely remove the clip? Wouldn't want to break something by pulling the wrong way.
Shark
Oswego, IL
Remove the bezel and with your thumb on the center of the clip push down slightly and forward (in the direction of the bezel) and it will slip right out if you have to force it STOP your doing something wrong hope this helps.
Size15's
Kettering, England
Either the SW02 (designed for use on a WeaponLight) or the Z48 Clickie intended for flashlights (same clickie - easy grip styling on the SW02 follows SW01 design)
Al
