I am not sure where this thread belongs, battery or general flashlight so please forgive me
:thinking:
Can i fit 3C cells inside 2D body? and if i would need 4 cells inside 2D body which type of battery should i use?
Thanks
I would start with how much power, volts and amps you need for your light. Also what do you have and what would you need to buy.
For example:
I'm running my Magled 3cell drop-in in a 2D mag with 3C cells for the correct voltage.
I will be modding it with a 3XCree module which can run on 3.6-9V. I have a great charger for NiMH AAA/AA cells along with 8 eneloops I'm not currently using so the KD 3AA to 1D adapters are a great option for me.
Cost $3.00
I could also go 2x 18650 since I have a Li-ion charger that can charge them but the cost of the batteries exceedes my other option.
Cost is at least $10.00
If I went with 3x C NiMH cells I would have to buy new cells and a new charger.
Cost is around $40.00
I can continue on with Li-ion C, D cells, sub-c cells but that's pretty much how I view it.
