Re: Flashlight Buyer\'s Guide added
I've been using NiMH AA's in my Minimag for a year or so. They work fine. Brightness is maybe a little less than with brand new alkalines, but equal to alkalines that have been in use for a while, and stays steadier. Runtime is fine, I don't use it enough to care about any differences, when the light starts dimming I recharge the cells. Self-discharge isn't too bad (I can leave the NiMH in for months). I also tried a NiMH in a CMG Ultra and that worked fine too, maybe with less runtime than an alkaline but still plenty. The voltage drop might be an issue with very marginal designs like two-cell LED flashlights with no step-up converter. But flashlights like that really shouldn't be sold.
One other issue, the guide mentions LED's being much more efficient than incandescent lamps, but I think that's only true of monochrome LED's. With white LED's, losses in the phosphor make the efficiency about the same as incandescent. You still get much longer useful battery runtime, since an incandescent on a weak battery will glow orange and then quickly drop down to infrared, while an LED will stay white (or whatever color). A white LED at 1/10th of its normal brightness is still useable.
LED's are getting better (they may double in efficiency over the next year or so). However, for now, fluorescent and HID lights are quite a bit more efficient than either regular incandescent or LED's.
While I'm at it, a comment on your review: they are great, very informative, however there's one piece of info that I always want, which is the weight of the flashlight with and without batteries. If you have a postal scale, can you start putting that info into your reviews? Sometimes there are manufacturer specs (e.g. at brightguy.com) but those are often incorrect.
Keep up the good work!
