gav6280
I have learned that Watts = volts x amps.
So one Cree q5 uses a fv of 3.7V. So Driven at 950mah = 3.515 Watts.
So 7 Cree q5 is 3.15 watts x 7 = 24.605 Watts?
This is Driven by the blue shark convertor board which is approx 90% efficient so the loss is 10% which = 2.46 watts?
So Cree's + Blue shark should use approximately = 28 watts?
Still with me.....
The 7 Cree should pull from the shark a total Forward voltage of 3.7 x 7 which = 25.9 total forward voltage?
Hang on in there....
I want to use a 6 cell 4000mah 22V Lipo battery which has a max hot of the charger voltage of 4.2V (6x4.2) = 25.2.
1. Is this just about going to be ok as the blue shark is a boost only driver and i dont want to kill it, expensive to UK.
2. So how do i work out how much current will be being drawn from the battery to check it is below the blue sharks 4A max input level?
3. Assuming all the above is correct? I think my battery then has 88WH? So my theretical run time would be 88 mwh / 28 watts = 3 hours?
Pheww.. Please feel absolully free to correct me in any way you like.
I just needed to know that i can use 7 cree with a blue shark and get 2 - 3 hour run times with a battery that fits in a cylinfer with internal diammeter of 62mm, if the above all works then i think i have cracked it yippeee....
Thanks.
Still with me.....
Thanks.
