SFfanman
- Joined
- Nov 12, 2009
- Messages
- 437
After waiting some 3 weeks for my Arc6 to arrive, it finally came. Awesome little pocket rocket was my first impression. Totally stoked to break this little guy in but when I wanted to take advantage of all its features, I was left behind in the dust. I can access the low-low and the high but not the virtual stage. When I try to program it, I am left with: twist, level one, click on and off: sticks on level high (instead of on and off high flashing for 10 times). I thought it might be excess lube so I wiped most clean on the piston and still the same. Is there anything an amateur flashaholic can do (ie: remove spring or cut spring) to make the piston engage and disengage as normal OR is the problem something else and I need to send it back to Arc? Anyone run into the same situation?
