cyclopsed
As I anounced in my very first post, it shall be simple.
So here it is my first « construct », I call it a construct as it is what it is: Quick, dirty, but simple.
Thanks to all at CPF for ideas, issues & diverse turn arounds, sold parts, fun.
Special thanks to ursuspeleus and his ACETOLED for the main idea
knowhow: soldering, sawing, screwing, glueing
construction time: 1 week (yes, the epoxy had to harden too)
oh yes, ehhhrrr... sorry for metric units, I´m from the old continent...
parts:
1x SSC-P7
1x AMC7135 350 mA driver
1x AMC7135 2800 mA driver
1x controler "NanoDim" (or any other that allows dimming with a trimpot)
glass fiber epoxy board
1x on/off switch
1x 3x4 rotating switch
1x trimpot 10k
2 compound epoxy glue
non-conductive thermal epoxy
4x4 cm square tubing, 2-3 mm strength
reason for choices:
SSC-P7 – nuts idea, next will be Cree MC-E (4 individual dies)
controller: I wanted a construction that can be dimmed with a pot.
rotating switch: in mode low it will consume a maximum of 350 mA/h
on/off switch: a necessity to reset the controller when it freaks out (once in overdrive, no way to reset it than switching completely off)
all the rest: just a matter of commodity to get into the stuff whilest learning.
I´m sorry, the pics from the assemby are gone, but the finished product is below.
1st round
- Starting with cutting a 6 cm piece of 4x4 cm rectangular tubing. (2mm strength)
- 2x 2,5mm boreholes for screwing the P7 to the tubing (3mm steel screw in 2,5mm alu hole keeps tight)
- 2x 3mm boreholes for the P7 connection wires
- Mounting the P7, with thermal epoxy, then screwed (if you like to screw it)
2nd round
- Cutting acrylic glas, 3 pieces 4x4 cm, 2 having a bore hole fitting the SSC-P7 into.
- Epoxy glueing the acrylic glas to a sandwich, smoothing the sides, sandpapering the top,
- Epoxy glueing the acryl sandwitch above the P7
3rd round
- cutting glass fiber board : twice 4x4 cm & twice x 3,6x3,6cm
4th round
- sandwiching one 4x4 and one 3,6x3,6 cm board, adjusting it the smaller fits into the tubing, the larger covering the tubing (do not yet glue it onto the tubing!!!)
- drilling a hole for the rotating switch
- fit the rotating switch onto the drilled board (take care it does fit into the tubing)
- you may use additional epoxy glue for water tightening the parts
- call this side board A
5th round
- drilling 3 holes: for the trimpot, the on/off switch and cable
- fit the trimpot, the on/off switch and cable onto the drilled board (take care it does fir into the tubing)
- call this side board B
6th round:
- glue with non conductive thermal epoxy the 2 prewired AMC boards and the controller onto a 2x6 cm aluminium bit (or epoxy board)
- do soldering between the bords
- glue the resulting board into the 4x4 aluminium tubing, I kept it tight with clamps
7th round:
- solder the wires from boards onto the rotating switch (side board A)
- solder the wires from boards/switch to LED
- fit sideboard A to side of 4x4 tube (everything fits?)
- glue side board A to side of 4x4 tube
8th round:
- solder wires to trimpot, on/off toggle, battery cable (side board B)
- do check with connected batteries if everything is OK
- fit sideboard B to side of 4x4 tube (everything fits?)
- glue side board B to side of 4x4 tube
9th round:
Finding a solution to fix the construct to helmet or anything else:
I did it with o-rings.
It´s splashproof, not watertight. That´s next step.
run times:
high mode @ 2800mA, not dimmed: around 3h 46min on 2800mA, then I stopped although still shining.
low mode @ 350mA (moon dim), still OK after 26 hours
batteries 4x Eneloop in series (ok, it should be just 3, but I was to lazy for adapting a battery holder)
plan:
face:
right:
left:
top:
ON
parts:
1x SSC-P7
1x on/off switch
1x trimpot 10k
reason for choices:
1st round
2nd round
3rd round
4th round
5th round
6th round:
7th round:
8th round:
9th round:
run times:
plan:
face:
right:
left:
top:
ON
