In the interest of science and safety, I did a quick test on 4 things: three sizes of beaded metal chain ("dog tag" chain)and on 1mm "stretch magic":
Not a scientific test by any means, No spring scales or stress gagues etc. Just 4 X four pound weights and my hands .
The black 2mm brass bead chain (that I was selling for a while on my ARC Accessories page, and some of you guys bought) held 16 pounds if you applied the tension slowly, but you could kind of sense that it was near it's capacity with just a static load. A slight upward jerk of the hands broke it easily.
The 2.4mm brass bead chain held the 16 pounds easily, and you could kind of bobble it around a bit without breaking, although a moderate upward jerk of the hands broke it.
The 3.1mm nickel-plated steel bead chain held the 16 pounds easily and you could kind of sling it around pretty well without breaking. I had to jerk the 16 pounds quite hard several times to get it to break.
Although the strength of this stuff was about what I imagined, I was kind of surprised at one thing: I expected the little snap links to be the weak point, but they all held and the chains themselves broke.
The 1mm Stretch Magic stuff held 8 pounds ok, stretched by about 60% in lifting the weight slowly and you could kind of bounce the weight gently, and get up to about 80% stretch. With 12 pounds on it, the line broke before it lifted the weight completely from its support. About 100% stretch at the breaking point. So I guess the 1mm stuff has about a 10 pound static tensile strength, but since it stretches so much it could be more useful for some tasks than metal chain, and vice versa.
Oh, they make 1.5mm Stretch Magic cord too. And all four sizes comes in several different colors.
One kind of neat way I use it is to hang my chuck keys for my flex shaft machine, drill press and lathe. They can dangle close to hand, yet out of the way, stretch to where I need them, and never get lost. /ubbthreads/images/graemlins/smile.gif
