[REVIEW] NAITHAWK M.1 & M.a [PICS HEAVY]
  • Thread starter z_dragonphoenix
  • Start date
Z
z_dragonphoenix
Guest
I got the two products three days ago. To my point of view, they are fantastic! As it presents, the best reliable partner in the dark! Here comes a brief review, including several parts: introduction, specification, lumen comparison, runtime, outdoor beam.
Introduction
NaitHawk M.1, M.a series adopt advanced electric circuit which controlled by magnetic-sensing numerical dimming which make clearer tap position and dimming convenient, which is the revolutionary breakthrough of flashlight. Use of CREE R5 XPG LED, with effective circuit and a lifetime of 50,000 hours, Constant-current excellent performance with maximum output of 260 lumens, runtime last for 100 hours.
M. 1, M.a series products adopt large current positive switch, Cooperate with tail groove, users can fast and accurate for tactics shoot and dedication of action. Magnetron 6 modes dimming, Meet various lighting needs. When need for a long time tactics shoot, you can choose the Strobe mode, a short time to make the blindness for the enemy attack. Outdoor walk, you can use the light middle mode. Then for a long time saving lighting, also can clear observation nearby roads. Low mode for camp lighting and the family illumination lighting use, maintenance and close lighting not dazzling. When reading a book, can use Lower low mode, lower brightness not dazzling, and eye protection at the same time, also can see text clearly in the dark. M.1, M.a series products not only consider when designing tactics of professional lighting, but also can satisfy with family, industrial, outdoor lighting needs. Fully exert its professional, practical, the fashion product positioning.
Specifications:
l Advanced rotate 360 degrees digital magnetron 6 modes dimming circuit;
l Premium CREE R5 LED with a maximum output of 260 lumens;
l 0.9-4.2V Wide voltage design;
l Constant-current performance;
l High transparent glass, hardening treatment;
l Large diameter reflector (24.5mm x17mm),The lighting distance can reach 200m;
l Reflector of good quality maintains both great throw distance and spread, perfect beam pattern;
l T6061 aircraft aluminum alloy, corrosion resistance?resist compression ability;
l Mil-Spec Type III Hard Anodized finish;
l Waterproof to IPX-8 standard;
l Able to Tail stand
l Tail groove bilateral symmetry, switch operations accurate and fast;
l Good quality tactical switch, high 50,000 times anti-aging test;
l Long running time, Continuous lighting 100 hours above;
l Size (M.a): Head diameter: 27mm. Tube diameter: 21mm. Total Length: 98mm;
l Size (M.1): Head diameter: 27mm. Tube diameter: 22.5mm. Total Length: 135mm;
Output and Runtime:
l M.1
Battery: 1*18650 Lithium battery
High?260 Lumen 4 hours
Mid?130 Lumen 10 hours
Low?50 Lumen 20 hours
Lower low: 3 Lumen 100 hours
l M.a
Battery: 1*123a Lithium battery or 16340 Lithium battery
High?260 Lumen 1.5 hours
Low?50 Lumen 11 hours
Lower low: 3 Lumen 50 hours
Two cases
M.1 and M.a
Warranty card and accessories
M.1
M.a
M.a with AA extension
M.1 and M.a
Rotate 360 degrees digital magnetron
AA extension
Attack head
Floatability anode design
CREE R5 LED
Tactical switch
High quality thread
With LD10 and G5S (a replica of surefire C2)
HOLSTER
M1 VS Ma (18650 VS 123A High mode)
M1 VS Ma (18650 VS 123A Mid mode)
M1 VS Ma (18650 VS 123A Low mode)
M1 VS Ma (18650 VS 123A Lower Low mode)
M1 VS Ma (18650 VS AA High mode)
M1 VS Ma (18650 VS AA Mid mode)
M1 VS Ma (18650 VS AA Low mode)
M1 VS Ma (18650 VS AA Lower Low mode)
M1 VS Ma VS G5S (18650 VS 123A VS 18650 High mode)
Ma VS LD10 (AA HIGH VS TURBO)
Ma VS LD10 (AA HIGH VS HIGH)
Ma VS LD10 (AA MID VS MID)
Ma VS LD10 (AA LOW VS MID)
Ma VS LD10 (AA LOWER LOW VS LOW)
Ma VS LD10 RUNTIME (AA HIGH VS TURBO)
0mins
10mins
20mins
30mins
40mins
50mins
60mins
70mins
80mins
90mins
OUTDOOR BEAM
M.1 HIGH
M.a 123A HIGH
M.a AA HIGH
G5S HIGH
* 123A battery used in this review is Energizer lithium 123A; 18650 is SOLARFORCE protected 2400mah; AA is SANYO eneloop.
* XENO G5S: a replica of surefire C2, R2WC (solarforce single mode).
M.1, M.a and accessories provided by NAITHAWK for review.
***END***
Craig K
These look interesting, anyone know how the Magnetron ring works, is it like a HDS rotary type thing?
brucejiang
England
they are not real HAIII, maybe HAII
the runtime given by the offical is not correct....
