GarageBoy
Is the regular LD01 now current regulated or was that the SS model only? Thanks
Was it ever confirmed that the LD01 R4 is current regulated?
Does that mean it can't take a 10440?
The specs on the instruction sheet that came with my LD01 stainless says it's a "Cree XP-G LED (R5)" and "Digitally regulated output - maintains constant brightness" and the package claims "Max 77 Lumens"
I notice the text on that spec pic says Max 72 lumens. Is the R5 "better" or "worse" than the R4 (I know some things are subjective) and is this "current regulated"?
I'm just learning all the technical aspecs of being a flashlight addict, so thanks for the patience.
The R4 and R5 are to do with which BIN Cree place the emitters in depending on their luminous flux, or efficacy.
See http://www.cree.com/products/pdf/XLampxp_b&l.pdf
R4 binned emitters are between 130 and 139 lumens @ 350 mA.
R5 binned emitters are between 139 and 148 lumens @ 350 mA.
Your LD01 SS is current regulated rather than PWM.
See http://www.fenixlight.com/viewproduct.asp?id=132
Essentially, in any production run of emmitters, some are brighter than others at a given amount of power input. And some have different chromaticity tints also.
So after a batch of production, cree tests each emitter, and bins it based on the characteristics it displays, in terms of efficacy and chromaticity.
... more "romantic" ...
