IsaacHayes
White LED\'s other than Blue LED + Yellow Phosphour
Why was blue + yellow chosen? Efficiency? Is there any other combinations that would result in better output or consistancy?
Think about these..: (note, you could have a X colored LED with Y phoshpur, or Y LED with X phosphur) Where X=1st color, Y=2nd color.
Green + Purple (R+B)
Red Cyan + (G+B)
UV/Blue + White(phos)
RGB(led) + White(phos) <-- Helps blend the RGB dies.
As you can see you could have a Red led with Cyan phos, or a Cyan led with red phos.. The red led would be the most effeicent probably..
Red Cyan + (G+B)
