I can't let this go. I guess if I had some time I'd research it, but for now I'll just state my objection to this concept of space-limited influence of the magnetic field... (My apologies to Gauss, Maxwell, and many others for my poor memory)
Point 1.
If you vary a current, then you get a corresponding induction of magnetic field. The converse is also true. E&M are intertwined as long as one is variant. As a result, a varying magnetic field is electrically detectable. (And if it's a very small amplitude, then its detection only requires more sophisticated electronics. Thus, 4ft limit is BS.)
Point 2.
If you look carefully at the 2-D image of a magnetic field, say you're remembering what those iron filing experiments look like, then you'll notice that the field does not die off at any point. It drops very quickly yes, and approaching the poles there is lots of dissipation. However, nowhere around the magnet is the field nonexistent. Thus, the "bubble" blather still sounds like marketing BS.
Someone please correct me...
