Perhaps not yet in production, but that is amazing for the bar to be raised by that increment.
http://technews.tmcnet.com/news/2011/05/09/5496319.htm
I believe by standard room temperature testing they might be running the LED on a large enough heat sink so the base plate is more or less at room temperature. Obviously the die will be somewhat warmer. I also think as LEDs become more efficient the 85°C being adopted by some producers will be less and less relevant. An LED only heats up because it's less than 100% efficient. At 231 lumens per watt, I'd estimate you're getting at least two-thirds light and only one-third heat. A 100-watt replacement using such an LED would only use about about 7.5 watts (plus ballast losses which might be another 10%), and produce around 2.5 watts heat. Difficult to imagine any part of the lamp, even the LED die itself, reaching 85°C even in a totally-enclosed fixture.Does "standard room tempurature testing" imply 25C instead of the 85C being adopted by most producers? If they can translate those gains into product in the near future then that would be incredible! I would like to see a 6500 K four die myself.
That actually makes a good case for remote phosphor which spreads the heat over a relatively large surface area. This makes cooling the die almost trivial. If we use my earlier hypothetical 100 watt replacement for an example, you have ~1.4 watts Stokes losses (dissipated easily over the globe by using remote phosphor), and a mere ~1.1 watts at the LED die. Even with a small heat sink, the die will practically be at ambient ( at most 10°C above).I hope they write a paper about this like last year.
The blue base diode needs to have at least 85% wall-plug efficiency for something like that. Incredible.
This also changes the cooling paradigma: More heat is generated due to stokes losses in the phosphor compared to the the die itself... with obviously worse thermal pathways.
Just to be clear, is the article stating:
-it is a single die?
-it is around 4500K?
-its forward voltage is about 2.86?
-it is being powered at only 350mA?
2.86 volts * .350mA = 1.001 watts
Holy cow!
That's nuts!
When can I buy the warm white and high CRI version? :twothumbs
There of course remains the minor challenge of surface brightness. General lighting applications are not very sensitive to this, but flashlights certainly are. At low current densities, surface brightness is going to be low regardless of the technology.
Google high CRI Paul.Just a thought on these Leds and colour rendition?
Paul
I was poking around on a circuit board today , using a D11 as it was a bit dark in there and i noticed for the first time actually , that when i was looking at the bands to read the values of resistors (old style) those colours did not show up right and had to swap to a incan .
Paul
Honestly, I find cool white LEDs make it MUCH easier to read the white lettering on black background present on most integrated circuits. As for resistors, incans might offer superior ability to distinguish between red and orange bands (and sometimes they pick colors which are really close), but it comes at the expense of being able to distinguish violet and blue from each other, or even both from black. For resistors then I think something like a 4000-5000K high-CRI LED might be ideal. Nowadays though I mostly use surface mount resistors which have the value numerically marked on them. Much easier than the color band system.I was poking around on a circuit board today , using a D11 as it was a bit dark in there and i noticed for the first time actually , that when i was looking at the bands to read the values of resistors (old style) those colours did not show up right and had to swap to a incan .
Paul
I am surprised, though, that this was achieved using a 4500K LED rather than a less useful, less pleasing 6000K LED.
