Lil black plastic doohickey came off my TL-3\'s LED
I've had my SL TL-3 5 watt Luxeon LED light for about a week. It's the focusable model, so I've been fiddling with the focusing quite a bit.
I noticed the next day I had it, that the bright spot of the beam would alter each time I focused it. It started to get irregular dark spots in it that would disappear as I moved the light closer to or farther from the wall. It wouldn't repeat the same beamshot twice in a row.
Also, it developed a brighter spot off center in the bright spot. I was becoming less and less impressed with the brightness of this 9 volt Luxeon Star light. I mentioned the anomalies to another member here and he hasn't had these problems.
I could actually tolerate looking straight into the emitter when it was on briefly, which I couldn't do when it arrived.
A little while ago I unscrewed the bezel and a little, black, thin plastic (vinyl, like shrink wrap?) popped up loose inside the bezel.
This little doohickey is a tube about .5" long. I tried to carefully replace it down over the emitter, but it must have been heat shrunk on. It's too small for me to get it on and I don't want to scratch the emitter dome or whatever that's called.
My congenital condition (5 thumbs on each hand) prevents me from work more delicate than twisting bezels and tail caps. /ubbthreads/images/graemlins/frown.gif
So, I just left it out and reassembled the light. Now it is back to the original, rods-and-cones-searing brightness. The dark spot and brightspot-within-the-brightspot anomalies have vanished. The brightspot may not be as well defined on the periphery as it used to be, but I'm not certain, I'm still seeing square spots.
/ubbthreads/images/graemlins/thinking.gif
Is it necessary to put this doohickey back on for protection of the emitter assembly or sumpin' ?
BC
BC
