madrabbitt
- Joined
- Aug 1, 2008
- Messages
- 32
As the title says. I need recommendations on a GU10 base LED bulb.
Price is the primary concern, but quality and longevity need to be considered as well... a 5 buck bulb wont help if i have to replace it once a month, even if replaced for free.
Ideally, im trying to keep it under $10 per bulb, as I need 4 of them.
This is specifically for a track lighting fixture for my apartment's living room/kitchen area. Currently running 4x50 watt halogen bulbs, and the fixture NEVER gets used, because its too damn bright at night, and the room has a lot of natural light in the daytime.
Looking for between 1-3 watts per bulb, ideally. There are no heat concerns, as its an open fixture (not recessed). Flood beam preferred, but spot is doable... I think i'm going to end up pointing all the lights towards the ceiling and walls, vs straight down, so the application is more of a accent light vs actually lighting the room.
