Sold/Expired Spy 007 / Tri-V Titanium Button inserts for tritium
mohanjude
Cardiff, UK
Thank you for your orders.
3 trit buttons
The first buttons to be milled will be the ones without trit orders as I am waiting for trits. I will post each members order as it completes on this thread. Completed buttons that are paid and shipped will be marked Green. Buttons that are ready and awaiting shipment will be marked Blue (payment marked in purple).
I would recommend that you polish the surface of the button with some metal polish. It is probably best you decide on how shiny you want it. I will polish the surface of the button if I am installing trits unless I am told otherwise. Notice the 1st picture with parallel slots mounted on the light - it had less than 10 seconds on a fine water sand paper (800 grit)
OK you all know that I made Titanium buttons / extended Buttons for Steve Kuku's e-switch.
Having gone mad with tritium slot milling on the torches and buttons I made some Titanium tritium button inserts for the legendary Coolfall's Spy 007 and Tri-V flashlight sometime ago for my own use. I made a handful for my lights 6 months ago and left in on the back burner.
Following several requests I have made some more titanium button inserts and will be in a position to sell them to my fellow CPF friends.
I only want to recoup the cost of the material and the time to mill the slots. Cost will be $25 plus postage for the buttom insert which include the cost of the milling upto 3 slots.
The button has a total thickness of 3.2mm - 0.7mm fills the recess on the Spy switch and the rest is proud as per pictures below. Plenty of material to mill 1.7mm trits slots upto 6mm long on the surface. The diameter of the button is 10.5mm. It is Titanium and matches the rest of the light.
I can mill the usual 3 slots either as a triangle, 3 parallel (6mm or 5mm length slots) or other design if you can think of another design that will fit in the area. The predator offset pattern will only be possible in 5mm slots due to space restriction.
Postage will be $5 airmail or $12 tracked. Considering the cost of the button I would stick to regular airmail. I will try and do the milling as soon as possible but please bear with me as I can only do it in my free time.
The button is push fit - it fits tight in the recess and there is a gap so you can prise it out. You don't need to glue it in as it is a snug fit.
You will see the button in the box - there are 'nipples' which are used to hold the button while I mill the slots. I will mill the nipples out as flush as possible.
Anodised buttons (Ukmidnite) - his excellent photography
6 trit buttons - run commencing 28.1.13
Normal vs thin profile buttons - added 18.1.13
Very low stock on 3 trit button
Prototype 6 trit button offered now - see below - final button ready and in stock.
Sales thread
If you want any buttons please post your interest on this thread.
Current orders (* plus tritium installed ->each tritium vial @ $8.50 installed)
Buttons: original 3 trit buttons
*1. Chipwillis - 2 Buttons 3 slots parallel green trits 6mm - trade 16.12.12. Thanks - buttons ready 12.01.2013 - Shipped 14.1.13 - RJ994705156GB
*2. KuanR - 1 button - 3 slots triangle ice blue 6mm -
Paid 19.12.12 - thanks - ready 31.12.12 - Shipped 04.01.13 RJ779473216GB New button shipped 14.1.13 RJ994905099GB
*3. Tanasit - 1 Button 3 slots parallel and triangle x1 , Predator x1 - trit colours random
6mm and Predator random 5mm paid 22.12.12 thanks - buttons ready 12.1.13 - Shipped 14.1.13 - RJ994705071GB
*4. Benchiew - 2 buttons 1 slot each plus spare trit - blue 6mm - Paid 19.12.12 - thanks. completed 27.12.12 - will be shipped 29.12.12 RJ643457315GB
*5. Silgt- 2 buttons - double parallel green iceblue 6mm and
predator offset red orange yellow 5mm - received payment 27.12.12 - thanks - Buttons ready 12.1.13 - awaiting other items to be shipped together. thanks
6. Stoli67 - 2 buttons - Predator offset 5mm Paid 16.12.12 - Shipped 18.12.12 - RJ779471918GB - Thanks
7.light11 - 2 buttons - parallel - 8mm centre trit + predator offset 5mm - Ready 18.12.12 - shipped 19.12.12 RJ272054091GB Thanks
*8. Glock18 - 2 buttons - parrell and triangle
6mm Green trits - Ready 12.1.13- Payment received with thanks 13.1.13 - Shipped 14.1.13 RJ994705111GB
9.tinycrumb - 2 buttons - parallel 6mm and predator offset 5mm -Ready 18.12.12 - do you still want these? 26.12.12 - since I have had no response in 8 days I will allocate these 2 buttons to others. Sorry I have not heard or received payment. A PM would have been appreciated to me know .....
*10.andrewmac - 1 button triangle with green trits 6mm - Buttons ready 12.1.13 - payment received 12.1.13 Shipped 14.1.13 RJ994705139GB
*11.hel - 1 button - parallel ice blue trits
6mm - paid 20.12.12 - thanks - Buttons ready 12.1.13 Shipped 14.1.13 RJ994705142GB
12. H-nu - 3 buttons - 2 Predator offset and 1 Triangle - all ​5mm Ready 19.12.12 Pd - shipped 20.12.12 RJ994704371GB - thanks
*13. Elnino - 1 button parallel 3 green trits 6mm - Buttons ready 12.1.13 -
payment received 14.1.13. Thanks Shipped 14.1.13 RJ994705108GB
14.ffemt6263 - 1 button 3 slots - shorter slots (Bart) 5mm - Ready 22.12.12 Paid 22.12.12 thanks Shipped 24.12.12 RJ994704725GB
15.murpharoo - 3 buttons - parallel x3 6mm - Ready 23.12.12 Paid 23.12 Shipped 24.12.12 AD557869234GB
16. Tobypra - 1 button - parallel 6mm ready 23.12.12 paid 21.12.12 Shipped 24.12.12 RJ994704748GB
*17. Elakazam - 1 button - triangle ice blue trits 6mm - Buttons ready 12.1.13 - payment received 12.1.12 - thanks. Shipped 14.1.13 RJ994705125GB
18. Launch mini - 3 buttons - predator offset 5mm, 2 parallel 5mm and 3 parallel 5
mm - in progress 23.12.12 - ready 25.12.12 - shipped 28.12.12 RJ643457324GB
*19. Samuraishot - 1 button - predator offset 5mm with trits blue, white purple - ready 29.12.12 trits allocated - Paid 01.1.13 - Shipped 04.01.13 RJ779473220GB
*20 easilyled - 3 buttons - 3 parallel each red/orange/yellow 6mm Paid 19.12.12 - thanks - Buttons ready 12.1.13 - SHhipped 14.1.13 AD557870042GB
Buttons 35
ALL BUTTONS SHIPPED 14.1.13!!
Trits Kuku 6mm $8.50 each installed:
1. ChipWillis - green3 x2, = 6
2. KuanR - ice blue3 x1 = 3
3. Tanasit - 6 trits random = 6
4. Benchiew - blue3 x1 = 3
5. Silgt - Green/iceblue, = 2
8. Glock18 - greenx3 x2
10. Andrewmac - green3 x1 = 3
11. hel - iceblue3 x1 = 3
13. Elnino - green3 x1 = 3
17. Elkazam - iceblue3 x1 = 3
20.easilyled - red/orange/yellow = 9
Green = 16
Ice blue = 10
Blue =3
red=3
orange=3
yellow =3
others = 6(random)
Trits 5mm Bart $8.50 each installed:
3. Tanasit - Predator - random 3 colours = 3
5. Silgt - Predator button red/orange/yellow = 3
19.Samuraishot - Predator button puple, blue and white = 3
Extra orders after completion above run (14.1.13) - added thin profile if required - order trits from Steve Ku or Bart please - now low stock...(06.03.13)
21. Stoli67 - 2 further Predator buttons. ( No trits) Payment received 18.1.13. Thanks Shipped 21.1.13 RJ779473729GB
22. rudi - thin profile button - triangle with ice blue and bare triangle - order 26.1.13. Shipped 29.1.13
23. Pm order - 3 Parallel low profile - all 3 green trits - shipped - 29.1.13
24. Kemosabex - 3 Parallel & predator offset + triangle sent for anodising 25.2.2013 Paypal received
25. Aikiman44 offset predator with 3 red trits -3 parallel trits: ice blue, green, ice blue - button to be milled 24.2.13 PP received 24.2.13 - posted 05.03.13 RJ874625456GB
26. Jumpmaster - x2 triangular Spy buttons - PP received - ready and posted 06.04.13
6 trit button Interest list - 22.1.13 taking place - $40 per button plus trits. Trit colours once decided will need to be ordered from Steve Ku directly who will ship trits to me for installation. I will make a small charge of $5 for installing the trits as there is a lot of Norland involved. Buttons are available to order ready milled and in stock - pm for fast dispatch.
6 trit button orders - still available
1. Samuraishot - button allocated 30.1.13 - Button sent to ukmidnite for anodising 02.02.13. Colour scheme to be decided. Posted 06.03.13 RJ779473803GB
2. KuanR - button allocated - trits ordered - PP received 27.1.13 - Trits received 01.2.13. Colour scheme decided. button completed 02.02..13- photo added - posted 04.2.13 RJ994705023GB
3. Murpharoo - button allocated 30.1.13 - PP received 15.2.13 all trits ordered - colour scheme decided - shipped 11.3.13 AD709083562GB
4. Ukmidnite- button allocated 30.1.13 - Trits self install - ZW594530153GB (also contains samuraishot ans Zanders buttons for anodising)
5. Light11- button allocated 30.1.13 - trits received 01.2.13 - All green on green - Button ready 02.02.13 - photo added button shipped 02.02.13
RJ64345800GB
7. Stoli67- button allocated 30.1.13 - trits available - PP received 31.1.13 - top row red orange purple (or ice blue) deep row - green yellow blue - button almost ready - pic added - posted 05.02.13 RJ874625186GB
8. Zander - button allocated - PP received 29.1.13 - trits have been ordered... Trits Received 07.2.13 - Colour scheme decided ANODISING (2 red, 2 ice blue, 2 purple and 2 pink - swap after pics) - Button sent to Ukmidnite for anodising 02.02.13 - posted 05.03.13 RJ874625460GB
9. S1lva- button allocated 30.1.13 - No trits required - Ready to ship - PP received 31.1.13 - button shipped 02.02.13 RJ643458015GB
10. SOYCD - button allocated - blank no trits - trade 27.1.13 - no trits - button shipped 02.02.13 RJ643458024GB
11. RIDE- button allocated 30.1.13 - trits ordered - colour scheme decided - PP received 31.1.13 - BOTTOM Green Green Green - TOP Blue Blue Blue
Trits received - button ready 17.2.13 shipped 18.2.13 RJ578344339GB
12. Wyldthng - button x2 - buttons allocated 01.02.13 - trits ordered - trits arrived 07.2.13 - colour scheme decided
PP received 31.1.13 - one button will all white on the bottom and blue on the top and 2nd button all ice blue at the bottom and blue at the top -button ready 17.2.13 shipped 18.2.13 RJ578344360gb
13. Andrewmac - 6 button request 02.02.13 - button milled 02.02.13 - trits received. Button ready 17.2.13 shipped 18.2.13 RJ578344342GB
14. Zoran - 6 trit button request 05.02.13 - button ready 07.2.13 - trits ordered from Bart (I will substitute colours in the correct size ;)) - PP received 07.2.1 - trits received - button ready 17.2.13 shipped 18.2.13 RJ578344356GB
15. Kemosabex - 6 trit button - button sent for anodising 25.2.13 - PayPal received - awaiting trits.
16. Service_wastl - 6 trit blank button pp received - posted 06.03.13 RJ779473794GB
UPDATE 30.1.13 - ALL 6 trit Buttons are nearly ready to have trits installed - if you want trits please order them now or tell me you don't want trits so I can ship the button to you following PayPal payment. If you want anodising let me know too so I can coordinate this with ukmidnite.
Please order trits from Steve Ku directly 1.5mm x6mm and ask him to send it to me. Please specify your exact sequence of colours by posting on the thread. I will make these buttons one by one on the mill and as before get them out to you. I suspect the delay will be receiving trits from Steve Ku as the buttons are now ready
Update 04.02.13 - I have completed the buttons for which I have had trits.
Samuraishot + zander buttons are with ukmidnite for anodising.
I will be away at the end of the week for 10 days - so wont be able to do any work on the buttons. There will be the rest of the family to accept trit packages that might come in - hopefully on my return all trits would have landed and the anodised buttons would be back.
update 16.2.13 - back again
all trit packages that were expected have arrived from Steve and Bart - I will now crack on.
Thanks for your patience whilst I was away.
Anodising:-
Kemosabex buttons sent for anodising 25.2.13
Waiting on trits:
kemosabex buttons, is waiting for long trits (short trits from Bart received 08.3.13)
chipwillis
Minnesota
I'll take 2 with the 3 milled. Normal shipping
Can you instal the trits also? If you have green?
Please PM payment details.
mohanjude
Cardiff, UK
I can install the trits no problem. Let me check if I got enough trits to cover. I will get back to you.
KuanR
Macau S.A.R.
I'll take one with 3 trits in triangle pattern, and it would be awesome if you can install the trits (ice blue or green), Mohan!
tanasit
I am also in for two of 3 triangular pattern and one 3 slots.
All for 1.5x6mm tritium vials.
Thanks,
Tanasit
Silgt
Can you do one with 2 parallel trit slots, and one with 3 triangle slots for me please?
stoli67
Sydney Austalia
I would like one with three slots shipped to Australia please.
Can you make it with an offset triangle (like in the movie predator ?)
Andrew
edit actually in for two!
mohanjude
Cardiff, UK
Looks like most people would like trits. I could order 1.5mm x6mm trits but I would need to order them in which will probably take a couple of weeks.
KuanR
Macau S.A.R.
I don't mind waiting, I would rather wait for trits to be perfectly installed than to do a messy job myself :)
GLOCK18
San Diego,Ca
I'm in for 2 Buttons 3 slots parallel and triangle
with trits installed.
6 green trits on mine.
Thanks
Jesse
hel
I'm in for one with 3 parallel slots and ice blue trits installed. Please PM for payment info, Thanks
H-nu
Ontario, Kanukistan
Mohan, that rocks! I'm in for three (3) buttons, each milled with three (3) slots in a triangular configuration. Please PM me with paypal address and total with shipping to Canada.
Thanks!
Silgt
Mohan, waiting time is perfectly fine, no problem for me since I'm currently out of country anyway. Please send me your PayPal address so I can send payments over for two buttons with trits, one with two parallel trit slots (green & ice blue) and one triangle predator style with 3 trit slots (red, orange & yellow) please. Thank you
ffemt6263
Ill take 1 with 3 parallel slots. No trits. (hopefully my trits get here from bart this time). Thanks Mohan.
