firelord777
Blackshadow is a relatively new brand to hit the market. They have already released quite a significant number of flashlights, and the one we have here today is their most powerful one yet. Well, powerful is an understatement. :duh2:
The market today seems to be almost saturated with so many multi-emitter XM-L flashlights. These things are capable of blasting 1,000s of lumens in your face with just the press of a button. If we go back a few years, we would have never dreamed LEDs would ever reach this type of power. Fortunately though, it is now a reality.
Here are the official specifications from Blackshadow:
Dimensions: 69mm(HD)×132mm(L)×93mm(H)
Weight: 395g(Without battery)
Color: Dark brown
Emitter: 4×CREE XM-L U2 LED
Battery: 4/18650
Circuit: Digital CC circuit, Low-voltage alarming system, Power indicating system
Mode: High-Mid-Low-OFF, hidden Strobe mode
Dimming: Smart button switch
Lumens: High 3500Lums - Mid 1500lums - Low 400lums - Strobe 3000lums
Runtime: High 1h10min - Mid 2h40min - Low11h25min - Strobe 1h40min
Material: Aluminum alloy
Lens: Impact-resistant optical lens with AR coating
Reflector: Metal reflector
Head & Tail: Stainless steel bezel ring, tailstanding tailcap
Waterproof: IPX-7, unable to support dive use.
Accessories: Tactical parachute-cord, Spare O-ring, User manual and Warranty card.
Mark: LED and mode are optional on your preference.
First Impressions
Well, when I received the package, Blackshadow had taped the whole thing like 20 times over. Have fun trying to open your Terminator for over half an hour. On the bright side though, at least customs will probably not want to mess around with your light. Seriously though, don't worry about the light during shipping; the box is practically bullet proof.
With those scary eyes and fangs, I nearly dropped the box out of shock! Not really, but still, it is intimidating.
So, my first thoughts were on how well Blackshadow provided ample protection and cushioning inside the box as well. Everything was organized and well presented. I wonder if they have an artist that designs and packages the whole thing. My next thoughts were that the flashlight felt just the right size. The weight isn't too heavy for its size without batteries, and it seems to be made to last a long time.
Construction
As mentioned before, the light is well built and has a gun grey finish to it.
The laser etched lettering is very clear and impossible to scratch off with my fingernails.
The two screws appear solid and match the color of the flashlight.
If you see below, you can see that you may need a special tool to disassemble the bezel of the reflectors. Me and my dad had to hold the flashlight very tightly and also apply a tremendous amount of force and pressure to unscrew the bezel. So, in short, don't try it, because it will be too difficult for most people.
To take apart the flashlight, you have to unscrew the body, which has a frosted o-ring. To insert batteries, make sure to insert them inverted. As in, negative goes in first, and the positive end should be facing you.
Inside the head, there is this big gold circle. Unlike my Fenix TK41, this finish doesn't scratch off everytime you change batteries. This tells me the flashlight is designed to last for a LONG time. :thumbsup:
Below, I show the types of batteries I use in the Terminator. I don't have the funds to buy batteries, so all my 18650s are from salvaged laptop battery packs. This also explains why I refrain from doing runtime tests. But my friend Candle lamp has made a good review here (http://www.candlepowerforums.com/vb...dow-Terminator-(4xXM-L-T6-NW-4x18650)-Review) :buddies:and if you scroll down, you can see his well detailed runtime graphs. Thanks to his graphs, we see that Blackshadow has incorporated thermal protection management to prevent overheating. His well-made review also reveals the Terminator has PWM on low and middle output levels. This means the flashlight turns on and off very quickly at high frequencies. A few people are sensitive to this, I am personally not.
Here I show you guys the flashlight and its cool green light. When you present to light to your friends, position the body in the on position and say to them it's a safety feature and it shows the light is armed. That will really amaze them, scare them, or possible both. Normally though, I use it as my night light. I must warn you, however, although it is bright and practically doesn't affect the battery life at all, it is too bright to directly use the light in a dark room to sleep. I have to suppress it a bit because or else, it's too bright, I cover it partially with another flashlight or something I have on hand. Another use is an emergency locator. I love it for this, let's say there is a power outage and you forgot where you left your regular flashlight. The green standby light will work wonders to quickly get the light and turn it on instead of fumbling for it in the dark. To turn it off, you only have to turn the light off a few degrees, very little in other words.:devil:
Below I have reflector size comparisons. The Blackshadow has a balanced reflector size. It isn't too small to be considered a dedicated flooder, but neither too large to be a dedicated thrower. Therefore, it has a balanced beam that can throw really good because of its beam profile and sheer power.
VS. Klarus XT20
VS. ArmyTek Viking
VS. Nitefighter F30C
VS. Everyone
Here I have some pictures to show the color of the finish, it is lighter than the F30C, and slightly lighter than the XT20.
Lanyard System
I have never seen a lanyard system as this one before. It is quite long, and has two positioning things. You can really play around with the lanyard whenever you're bored. The possibilities are essentially endless. I even tied the flashlight to a soccer goal post so my brother and I could play in complete darkness, and the Terminator as a portable stadium light. Ah, good old times eh?:huh:
Whitewall Beamshots
I have here for you some whitewall beamshots. All have initial exposures, and equal reduced exposures. No digital voodoo magic here guys::nana:
ArmyTek Viking X
Nitefighter F30C
Klarus XT20
Blackshadow Terminator
I guess the Terminator doesn't provide a "Blackshadow" LOL.
Office Workstation Ceiling Bounce Tests:
Same order as before:
ArmyTek Viking X (don't mind the toilet paper roll, I had to support it with something and just got a bit creative)
Nitefighter F30C
Klarus XT20
Size Comparison to Daily Objects:
Given the size of the flashlight, its mind boggling how much blinding light can come out of something so small, it almost seems surreal.:ironic:
Against a pair of sunglasses
Versus my English-Italian dictionary
Rock and rolling with its Pepsi cousin
Waterproofing…er…Terminator's Swimming Class
I find it sometimes amazing how manufacturers can waterproof flashlights, but I guess I'll have to learn that some other day, Terminator is bugging me to start his swim class already.:hairpull:
I bet Terminator is saying "class ended so soon?"
Outdoor Beamshots (BOOYAH!!!)
I'm sure many of you are curious just how good the Terminator scares away the darkness, so here it is::naughty:
Control (sun was setting)
Dereelight Night Master:
Klarus XT20:
Fenix TK41:
Black Shadow Terminator:
And Olight SR95S-UT:
ArmyTek Predator:
Klarus XT20:
Fenix TK41:
Olight SR95S-UT:
Control (from where I was to the trees is just over the length of a soccer field:
ArmyTek Predator:
Klarus XT20:
Fenix TK41:
Olight SR95S-UT:
ArmyTek
Dereelight
Klarus
Fenix
Black Shadow
Olight
ArmyTek Predator (fantastic little light that rivals the throw of bigger lights)
Dereelight Night Master (if you're looking for a light to play Star Wars, this is it, the beam is tight like a laser)
Klarus XT20 (same brightness as the SR95S-UT, but its more oriented for flood)
Fenix TK41 (Throws really good for 8 AA batteries)
Black Shadow Terminator (The Terminator name fits it well, it terminates every organisms' eyeballs if you shine it at them)
Olight SR95S-UT:
Another setting:
Sorry guys, I forgot to take a picture of the ArmyTek, we'll just have to start with the Dereelight:
Blackshadow, as previously mentioned is a new brand by all standards. However, they have proven to me that they have an exceptional and outstanding support and service team. I had an initial problem with the Blackshadow of a small crack in a lens, and they provided no questions asked not one lens, but two lenses. I am very happy with their professionalism. About dealers though, I'm not entirely sure, as of now, I got the light from China. Bottom line, I can vouch for Blackshadow's customer service and overall good experience. :thumbsup:
More to Come Soon
I will be updating this review with more stuff and testing, if there is anything you would like to request I do or test the flashlight, please feel absolutely free to ask or contact me.:rock:
Cheers,
Alain
Color: Dark brown
Battery: 4/18650
First Impressions
Construction
VS. Klarus XT20
VS. ArmyTek Viking
VS. Everyone
Lanyard System
Whitewall Beamshots
ArmyTek Viking X
Nitefighter F30C
Klarus XT20
Nitefighter F30C
Klarus XT20
Klarus XT20:
Fenix TK41:
ArmyTek Predator:
Klarus XT20:
Fenix TK41:
Olight SR95S-UT:
ArmyTek Predator:
Klarus XT20:
Fenix TK41:
Olight SR95S-UT:
ArmyTek
Dereelight
Klarus
Fenix
Black Shadow
Olight
Olight SR95S-UT:
Another setting:
More to Come Soon
Cheers,
Alain
