Either the kit or the light with it already installed. I live in canada
They've been out of production for several years. You might try a WTB in the Marketplace.
Those kits are long gone. Also 2* Li-ion batteries pushed to the limit is very dangerous. The 20 min runtime is not that good either.
The mm Pro and Pro+ (Pro+ available at MOUNTAIN EQUIPMENT CO-OPERATIVE) is brighter than the Aurora though probably less yellow than you are used to.
You may have to look for neutral or warm or high CRI tinted LED lights.
j2ledflashlight in Canada has the Fenix LD40 in neutral. This is a 4AA flashlight in a 2x2 side by side configuration.
eliteled in the USA has Fenix LD25-R4 Cree XP-G R4, NW LED 2xAA Model.
batteryjunction in the USA has Terralux Lightstar TruColor High CRI 185 Lumen Uses 2 x AA.
also TerraLUX LightStar 80 - High CRI LED FLashlight - 80 Lumens -Includes 2 x AAA Batteries - Grey or orange though these are dimmer than the aurora.
zebralight in China has SC51c AA Flashlight 85 CRI; SC51w Flashlight AA Neutral White; SC51Fw AA Floody Flashlight Neutral White. These are 1AA but very bright on high.
I have not kept up with the newer manufacturers but look for warm or high CRI LED flashlights at around 200 lumens running 2AA.
Go to your local Home Depot. They will have a Philips display in the home light bulb section. You can see how the newer warm tinted LED bulbs are no longer blue.
