BIGLOU
- Joined
- Jan 14, 2009
- Messages
- 717
I dont know how I would search for my specific problem and dont want to go through thousands of replies on the HDS threads. So my Ra EDC is not working, I have tinkered with it and no dice. Here is the problem first of all I install the battery by unscrewing the head from the body and not the tailcap the reason is because it is much easier that going though the tailcap. OK thats out of the way, so when changing the battery the light goes on on what appears a low mode right when I start screwing the body to the head then the light turns off after a few turns. I tried both a primary and a charged RCR123. I do use my Ra and it's pretty minty. I cleaned the threads and checked the wire thingy on the battery tube and I also did see that there appears to be some contact by the markings on the circuit board behind the led. I appreciate any help. These are a little more complicated than my SF 6Ps.
