WTS: Sunwayman T45Cvn
Skylumen
The modded light is a Sunwayman T45C
Manufacture Specs:
Features
CREE XM-L2 LED, with a lifetime of up to 50,000 hours;
Side switch on the top, 8 output modes:
Turbo: 980 Lumens (Automatically enter High mode after 5 mins continuous use to avoid overheat)
High: 470 Lumens (3.5hrs.)
Mid: 220 Lumens (10hrs.)
Low: 20 Lumens (130hrs.)
Strobe
SOS
Police Strobe
Slow Flash
Super-low Standby Current <50uA
Constant current circuit, constant output
Specifications:
Effective range of 278 meters
Intensity: 19200cd
Uses 2*18650 (4*CR123A/16340) batteries
Working voltage: 2.8~8.4V
High quality metal reflector maintains great throw distance and spread with an ideal beam pattern
Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top
Military Specification Type III- hard anodized body
Waterproof, in accordance with IPX-8 standard
Ultra-clear tempered glass lens resists scratches and impacts
Dimensions:
Dimensions: 41mm (head diameter) x 136mm (length)
Weight: 220.5g (Excluding battery)
Accessories:
Lanyard, O-ring
Mod Details
- XML2 6500K Dedome bonded to copper heat sink. Original is aluminum
- Current Bump to 3.8A while retaining factory UI (Forgot to measure factory draw. Will do soon)
- All UI are as factory. Original Low is still the same.
- LED permanently thermal glued to the light engine. This is crucial for great heat sinking and perfect LED centering.
- High is about 1250 LED Lumen.
- Throws incredible for a light this compact.
- Hot spot if very define and filled
- Beautiful beam. First Sample has no artifacts. I do not expect any.
Control:
Zebralight S6330 Factory 2400 Lumen (Much brighter in real life than photo suggest)
Baby K40vn (Ultra Compact) 1300 Lumen (Much brighter in real life than photo suggest)
I will add your name as fund is received. This helps me saves time. Refunds are issued immediately if you withdraw your interest.
$105
+15$ if you are outside of USA
You can become a CPF suppoter for as little as $2.50
Subscribe to CPF here:
http://www.candlepowerforums.com/vb/payments.p
hp
Send me an email and ask to receive my newsletter
PM or email me for payment instructions.
Email: [email protected]
Icehole
Texas
Re: WTS: Baby K40vn Thrower ... Coming Soon :)
Put me on the list!
:paypal:
jmpaul320
CT, USA
Put me on list plz
What is the light?
NowIC
put me on the list please
Dan50
Put me on the list also please
Diablo_331
Add me to the list please.
Tracker II
Hahaha, put me on the list please!
Jakeyb
Usa
you've been putting out some really neat stuff lately I can really tell you have a passion for this stuff and your work proves it.
TEEJ
NJ
LOL
Baby k40vn?
1SICKLT1TA
Very interested please put me on the list
pharmbob
Put me on the list too please :)
donn_
Great South Bay, LINY
I'm starting to wonder about your beamshots, Vinh.
This is shown in the first Vostro Mvn thread:
And this one, in this thread:
Zebralight S6330 Factory 2400 lumen
