tvsinesperanto
- Joined
- Dec 25, 2013
- Messages
- 19
Hi All,
I'm currently looking for a nice bright EDC light that ticks all the boxes, but no matter what I find, it's always lacking in one or more areas.
I'm pretty much a newbie when it comes to flashlights but I think I've done my homework &, after careful consideration, I've decided that the Olight S10-L2 Baton or the S20-L2 Baton is pretty much ideal for my needs except for the fact that the output is about 50% & 25% lower (respectively) than I would like. Ideally I'd like at least 700 lumens (although more is always better) but the S10 only does 400 & the S20 is only slightly better at 550.
My question is, in the real world, am I going to notice a lot of difference between the 550 lumens of the S20 & let's say the 850 lumens of the Fenix PD35? I'm hoping that the answer is no because the S20-L2 is just about perfect for me with the single exception of it's output.
Of course, I can get EDC lights that will put out 800+ lumens, like the PD35 that I mentioned (850 lumens), or the Zebralight SC600 MkII (>1000 lumens) but these both have other drawbacks (eg. larger size/weight, no tail standing, etc.) or lack nice features that the Olight baton series have.
So, it's a toss up. Do I sacrifice output & get what is otherwise a near ideal light or do I get the output I want but sacrifice other features, some of which are quite important to me? Not knowing how much practical difference there is between 550 & 850 lumens in the real world, I'm somewhat in the dark (pun completely intended).
Is the light level detection of the eye logarithmic like sound detection of the ear (i.e. double the brightness = 10x the lumens), is it a power of 2 thing (i.e 2x as bright = 4x as many lumens), or is it linear (i.e. 2x the lumens appears 2x as bright)?
I would appreciate any experienced opinions on the matter.
Of course if there is some way I can get the same features & durability of the S10/20 AND get 800+ lumens, please tell me. Even if I can only get that output for a few minutes at a time in some sort of turbo or burst mode, that's fine. As I said, I'll only rarely be using it for more than 5 minutes at a time anyway. If it's not possible from a commercial manufacturer, I've heard that some people will make custom lights to suit your needs. If I went down this route would I be able to get a high output in an S20 body? If so, how much am I looking at paying (ballpark figure is fine)?
In case it matters, this light is going to be used for the following:
1) Seeing where I'm going & avoiding obstacles when walking around city/urban streets in the dark. I have minor mobility issues & am a little unsteady on my feet. As a result, if I encounter any unseen & unexpected unevenness in the ground, I'm more than likely to end up on my arse. So, I need to see where my feet are going but I also need to see well ahead (30+ metres) so I can avoid obstacles.
2) Seeing things that have fallen into dark corners or under objects, working on cars or appliances, etc.
3) For inspection of small or fiddly objects when ambient light is poor.
4) Basically just everyday stuff.
Very occasionally it may be used while camping or hiking but it's likely to be only a backup light in those cases.
Any & all advice gratefully accepted.
Thanks,
TV
Thanks,
TV
