I just did this mod over the weekend. Works great. I also did one with a BB750 at the same time. Which is better? I don't know, different design philosophies for driving the 3 watt luxeon.
I did cut down the tailcap spring (using Dremel tool) so that it would fit down into the tailcap bottom. I cut off the top (narrow coils) and most of the bottom, so that spring tension of the wider coils holds it in place in the bottom of the tailcap. I did have to bend the narrow coils for sure contact with the C-cells (using pliers).
Also, I used the Dremel to sand the anodizing from the floor and sides of the tailcap, so that the spring made good electrical contact.
With kinda worn alkaline C cells, it pushes the luxeon 3 at about 400 mA. The light is good, but not outstanding. With NiCads (much less internal resistance), it pushes about 750 mA (same as the BB750) and is indistinguishable side-by-side from its twin with the BB750.
I highly recommend this simple and inexpensive mod. Also, the Hotlips heatsinks are a joy to work with.
Kerry
