yourgrandma
- Joined
- Feb 27, 2010
- Messages
- 5
I got pretty deep into researching a project long ago which fell by the wayside. I was just thinking about trying to tackle it one of these days...
Basically im trying to decide if, given a certain amount of space to work with (including heatsinking) Id be better off with more LEDs with smaller lenses or if larger more efficient lenses would make up for a missing LED or two.
I was planning on running XM-L2s and driving them fairly hard because the duty cycle would be low for this application. Probably would use a dimmable driver.(I cant remember many specifics on what I was planning anymore). I would probably need as much throw as I could get out of it but a wide, flat shaped beam would be desireable as well. I would probably be using as big of TIR type optics as I could and was looking to use 6 LEDs. Some combination of elliptical and tight spot optics would be used. If I used large reflectors Id only be able to fit 4 of them or maybe two reflectors and three TIR optics.
Would you choose a higher number of LEDs or better optics?
