What advantages does the H600fd III have over the H600fw MKII? It says better output and more efficient, but the specs contradict that.
The H600fd Mklll can run between 2.7 volts to 6.0 volts and can handle batteries up to 69mm, while the SC600 Mkll has voltage range between 2.7 volts to 4.2 volts and has the same 69mm battery maximum battery length. Also the H600fd Mklll has a frosted lens.
This allows the possibility of using CR123a's as backups.
You are correct. Only in a dire situation should CR123a batteries be used and not higher than a 'medium' setting.ZebraLight does not recommend using CR123A batteries for this or any other model I am aware of.
On its highest mode(s), a ZebraLight will pull more than the 1.5 amps that CR123A batteries are rated to supply. Note that the boost and buck/boost drivers used in ZebraLights draw their highest amperage when the batteries are low, so the problem is worse than what a measurement using fresh CR123A batteries would suggest. The adventurous spirits who are happy to risk their ZebraLights on CR123A are careful to use only medium and low modes. That helps keep current draws below 1.5 amps.
Will I notice a huge difference in weight going from the H31? It says it's almost an ounce and a half heavier but that doesn't seem like a lot.
The original. It just says H31. It's discontinued.
Just don't buy the Keeppower 3400/3500 mAh, they are too thick. I'm using an Eagtac 3500 mAh, but unprotected batteries work fine too.What is the best battery for the H600fd? Protected? Unprotected? 3400mh?
That actually sounds perfect. I don't like the " yellow" look. But I don't like the "bluish" look either. Sounds like it is the perfect compromise.
