Hi,
i would like to share my latest prototype - the handschmeichler 4.0
Some technical details about the hardware:
you can messure:
- air temperatur
- air humidity
- air pressure
- altitude
- brighness in Lux
- light color in kelvin
- max lux memory
- angle (spririt bubble)
to turn on the light, there is a classical switch on the side. to change the brighness there is a poti beside the switch. to change the color from white to red or 365nm uv you have to long press the button when first page (flashlite page with battery status, brighness level status and led color information) is displayed.
to change to the next display site you have to short click. each page have some special function with long oder doubleclick.
the software takes more then 40 hours to complete. i´m not a complete noob in that, but also no specialist. the mechanical side takes more then 50 hours to complete. there was many work to fit all parts inside. the display circuit board alone tooks more the 3 hours, cause there was a lot to do to small down to fit inside.
Short Video demonstration:
Thanks for Looking, Markus
- 1 x 128 Gbyte USB Storage
- 1 x Atmel 32u4 µC
- 2 x Osram Oslon high Cri
- 1 x Osram Oslon Deep Red
- 1 x Nichia NCSU276A
- 1 x Bosch BME280
- 1 x TCS34725
- 1 x ADXL345- 1 x Atmel 32u4 µC
- 1 x Bosch BME280
- 1 x TCS34725
- 1 x selfmade 7135 driver
- 1 x Oled 128x32 Display
- 6 x tritium vial
you can messure:
- air temperatur
- air humidity
- air pressure
- altitude
- brighness in Lux
- max lux memory
