So, it's like this:
I got the E05 a couple of weeks ago. In retrospect, I've made a mistake by not buying the LD02 instead.
Now, I need to determine just how big a mistake it actually was and act accordingly.
On a side note, I didn't buy the LD02 flashlight simply because I didn't know that it existed.
So, after receiving and testing out the E05 I realized that it had a problem and a potentially disastrous design flaw. After some research I stumbled upon the LD02 flashlight and now I'm wondering if I should simply scrap the E05 and replace it with the LD02. So, basically, with your help I want to figure out if the LD02 is actually better for me.
Personally, I've never liked lights with twist-switches but since the intended use was not EDC, I didn't really mind having it on the E05, especially since this little light had so much going for it.
So, the actual intended use is "second/third backup" light. It's supposed be inside my camera bag and unless some real s**** hits the fan, I'm not supposed to even touch it... However, if all my other lights fail and/or get lost, the little E05 must be ready to spring into action after years of zero use. The throw has to be strong enough to light my way in the mountains at night and/or signal for help. High lumen output is a must as well as the ability to conserve battery power in the lower output modes. Water + shock resistance, extremely long shelf life (battery).
The E05, along with a AAA Energizer lithium cell seemed to fit the bill nicely. When I received the flashlight, the first thing I did was test it with a AAA Energizer lithium cell in the High mode (to measure the burn time with this type of batteries)
However, after only a few minutes on "High", the E05 switched to the Mid mode. When I touched it, it was 'almost too hot' to touch/hold/operate. The temperature of the unit was approaching the 'uncomfortable' zone, so I figured that the thermal protection was triggered and that it was the reason for the output being dialed down. I immediately switched the unit back into the High mode. It was good for another 4 or 5 minutes, after which, it switched back to the Mid mode. Again, I immediately switched it back to the High mode. Since I was actually timing the performance , I had to play this game until the battery ran out, which was more than an hour, by the way.
Here are my questions:
• Why was the E05 flashlight unable to maintain its highest output in a room-temperature environment? Bad engineering? Sub par components across the production line? A defective unit?
• Does the LD02 flashlight exhibit similar behavior? Is it able to maintain its highest output, uninterrupted, for as long as the battery allows it?
• Does the E05 draw ANY current from the battery when it's idle? *My unit will have to be stored for years with the battery inside.
• Does the LD02 draw any current from the battery when it's idle?
Those are pretty much all the questions that I have at this point.
Thanks!
Thanks!
