I received the Nitecore TIP2 for the review from Nitecore.
The TIP2 comes in this box
The TIP2 looks like a squeezed version of the TIP, larger and thinner (62 mm x 27 mm x 14 mm)..
From the single XP-G emitter of the TIP, the TIP2 gets 2 emitter with a plastic TIR optic
Here with a BIC lighter (the smallest one).
Like the TIP, it features a removable plastic body encasing which acts as a clip. It fits on both sides so you can have the clip on the side you prefer.
There is also a blue LED indicator for the battery. Now, it has a separate window and does not glow under the switches.
The back of the light is connected to the body via 2 strong neodymium magnets. You simply pull (with quite some force) and the two pieces come apart. To reconnect them, just put them back and the magnet will hold them back together.
Here you can see the 2 magnets and the micro USB charging port in the middle for the integrated 500mAh battery. The light can be used while charging.
The magnets are strong enough to keep the light on a metal surface even when kept on the side
Here with the TUP
Defenetly a good looking light
In the hand
UI
Beamshots at 0.5 m
Output and runtime
This is how I got this plot: I run the turbo mode until the light stepped down. Then I decided to reactivate the turbo (second peak), and when the stepdown happened, I immediately reactivated it (third peak).
My thoughts
The light is well built and finished.
The levels are well spaced and the regulation is fine. The thermal regulation is there and it works.
I like the UI with direct access to highest mode.
The magnet system works well in practice and also acts as a cover for the micro USB port as well as for the magnets. No, it won't come undone easily, if you are asking that.
The clip-cover fits on the body snugly, it works well and it is IMHO much more elegant and discrete than the one on the TIP, while maintaining functionality. You can use it to clip the TIP2 to your clothes or to the visor of a baseball cap, making it an improvised headlamp.
There is no electronic lockout, although the switches are low profile and small, but you can choose between the daily and demo mode (which turns the light off after 30").
Nitecore took the already successful TIP and improved all that could be improved: better design and looks, better output, added thermal sensor, added detachable keychain feature.
I would like this light to come witha direct access to low mode, a neutral/warm tint, and to have an electronic lockout.
Thanks to: AntoLed, Zampa, Won.
Here with the TUP
In the hand
UI
Beamshots at 0.5 m
Output and runtime
My thoughts
