Klarus Visor Clip Motion Sensor Light HC3, Anywhere Anytime Light up Your Way
klight
Klarus Visor Clip Motion Sensor light HC3
It is Compact Size, slim design easy to fit with any hat, anywhere anytime light up your way
Max Output: 100 Lumens
Max Runtime: 27 Hours
USB Rechargeable and Battery indicator
Motion Sensing, just wave your hand to turn on/off light
180 degree adjustable
Learn more: www.klaruslight.com
parametrek
Added to the database. That 100 lumen mode really should be labeled as a turbo shouldn't it? As far as I can tell it almost immediately drop to half brightness.
Is there any word to what this might cost? It is a cute little hatlight and I am very excited that it uses a neutral white.
klight
Thanks for your suggestion, we will feedback it to our R&D team, thank you, this hatlight will be on the market soon, we will keep you updated
wacbzz
North of the South
That 100 lumen mode really should be labeled as a turbo shouldn't it? As far as I can tell it almost immediately drop to half brightness..
Klight - is this true? The price looks great on this, but does the light really drop its initial 100 lumen brightness that quick? Your runtime chart says 100 lumens for 4 hours. What is the actual runtime before it drops from 100 lumens? Thanks.
klight
High mode will run 4 hours, the highest brightness will drop after 3 minutes
