What is this Old Vintage Bulb Base type?
FlashyOne
Hi All,
I have a very old Perko battery powered boat lantern, looks like it took a 1.5V big dry cell. The bulb is 3/8" (major) diameter screw in type. I'm wondering what type of bulb to buy?
I plan to get an LED equivilant and already ordered two 4x D cell holders and can run 6v or 12v.
Anyone can help me know what the base to order would be much appreciated!
bykfixer
Dust in the Wind
They were called E10 base.
E for Edison screw in
10 for ten millimeters.
Any screw in was/is called E followed by a number representing the OD in millimeters.
Edit: So you start at a bulb site like bulb town in the E10 section. Then find a bulb number and check the voltage it takes. E10 bulbs are expressed in whole numbers such as #14, 222 or that sort of numbering monikor.
End edit
FlashyOne
Does the current bulb have a PR number? If it does, just find a current one with the same number that matches the voltage you will be supplying.
It's E10, I bought some LED's that are E10 and the threads screwed right in. What threw me was that I had NO IDEA that the metric system went that far back and was used over here at the time!
ZMZ67
Colorado
This is a good E10 LED drop-in, if you are still looking for one:
https://www.amazon.com/dp/B01631XMUY/?tag=cpf0b6-20
+1 on those! A really nice way to bring old lanterns/flashlights back to life. They are not polarity specific and will work with positive or negative polarity lights. Flashlights are typically positive polarity but old lanterns are often negative polarity.
