eebowler
Can't really afford a hotlips heatsink. Only alternative was to look for something else which can be milled into shape. Got the grand idea of using aluminum because of the ease of milling. First thoughts went to my bicycle's crank arms which were thick enough(0.75 in) and had a roundish part at the end which is just about the size of a 3D mag. Eventually discovered that the only I had available was too small.
One day walking arround campus, I saw a discarded door closer thingy. It was a heavy, rectangular block of Al with whatever mechanics inside to close the door .I thought that it was the perfect find. I am sure that the Al was at least 1/2 in thick. The weight of it said all I wanted to hear.
I had the thing for about a week before deciding to get a screwdriver and discovering if I had gold or a dud. Just to be on the 'safe' side, I asked an associate (not educated, but, more mechanically experienced than me) if it was safe and he said yes. I believed him. The screwdriver was worn, so I decided to open the side where I got the most leverage first. One central screw came out along with some really stink oil. The other 4 screws were holding down a metal plate to one end of the block . Of those 4, three came out with much force. The 4th was damaged and was giving me much trouble to extract.
Strangly, the plate was raised off the main body slightly and this gave me the oppertunity to pry off the top. I thought it was working when the plate began to give then...POP! OW! THUD! and CLANG! The plate,(about an ounce in weight) shot off of the body, colided with my knuckle, flew past my head and hit the roof directly above me before finding itself about 15 feet away on the floor across the room. /ubbthreads/images/graemlins/icon15.gif I lost about 4 drops of blood before pinching the wound shut(2sec?). Lost about 2 more drops before the bleeding stopped. The nurse cleaned the wound and bandaged a 'palet stick' (splint) to my finger so I wouldn't bend the joint to re-open the wound. How embarrasing! Now, it looks like I have a broken finger and worse, I wouldn't be able to do any hard cycling since one of my breaking fingers are out of comisssion for about a week.
The worst part I discovered when I was cleaning up my mess. The metal plate had stamped on it, in plain view: DANGER DO NOT OPEN! Gosh! I feel so stupid! /ubbthreads/images/graemlins/jpshakehead.gif So close to a serious accident just because I didn't take the time to read the obvious. Wasn't all that bad though. The aluminum is >1/4 in thick and can be used for a heatsink eventually.
Have any of you ever done anything stupid like this before? (please don't tell me that I am the only one /ubbthreads/images/graemlins/crazy.gif.) ( I also almost blew a hole in my skull with a starlight experiment gone wrong, but that is another story. /ubbthreads/images/graemlins/grin.gif)
