Hi
I am trying to mod my cheap bicycle headlight which runs on 2C batts side by side on a 2.5 volt stock PR bulb.
I bought the Rayovac KPR113. On the packaging it says 4.8 volts 0.75A, 3.6 Watt. But n the packaging it also states 6 Volts. So is it 4.8 or 6? The KPR113 at Radioshack.com is 4.8 volts. Does it meant the bulb can be overdrived to 6 volts?
I am thinking of using either 2 CR123s or 4 AAs, or 4 NiMH AAs (1.2v each instead of 1.5) Which will work best?
Thanx in advance! Pls help. /ubbthreads/images/graemlins/smile.gif
