js
*CLOSED*
Due to the discovery of the mag bi-pin drop-in Mag/MC hybrid, this option is superfluous and I am closing this thread and will no longer be selling these things.
A long, long time ago (it seems) I started an ambitious thread on making a drop-in replacement for the mag D cell lights switch/pedetal assy. There were many twists and turns, but skipping to the end of it all, I have concluded that the best solution is to modify the switch/pedestal assy the OA4D cookbook way, with molex connectors on the ends of the two wires. Check out the link, but essentially you just cut off the pedestal and solder wires onto the proper spots. Then run the wires--which have molex connectors on the ends--to bi-pin lamp leads.
This requires a Carley 1940 reflector and one of my ring-potted lamps, or the metal sleeve which Carley sells that allows you to secure one of their lamps into a set-screw reflector (such as the 1940).
There are many ways to do an incan mod, and this is only one of them. But in case people are interested, I am selling the following items for this method:
1. Bare molex connectors. 25 cents each if you send me a SASE (PM me for my address please). Or add 40 cents for shipping otherwise. These are what the TigerLight uses, and they are conservatively rated to 3 amps, but I have run 3.6 amps through them without any trouble.
2. Bare MIL-MAX connectors. 20 cents each with SASE, or add 40 cents for shipping. These are better than the Molex connectors for making up a socket, or bi-in to PR base adaptor, because they are enclosed and sealed. Unfortunately this makes it harder to attach wires to them.
3. Molex connectorized wires: For those who want me to do it all, I am selling completed pairs of red and black high strand count silicone insulated 20 gauge wires with the Molex connectors crimped and soldered on, and with shrink wrap. This wire is really nice stuff and is very flexible due to the high strand count and the silicone insulation (which is good to 200 degrees C). Cost is $3 shipped.
The picture below shows all of the products mentioned. The MIL-MAX connectors are the ones which look like minature tubes or barrels, towards the top left of the picture. Oops! and some spurious shrink wrap got in there in the upper right. Ignore it.
image removed
And once you install and solder them, you would connect them to a 1940 w/ lamp like so:
image removed
I accept PayPal, personal checks, money orders, or loose cash /ubbthreads/images/graemlins/smile.gif. However, if you want to use PayPal, please add 3 percent plus 30 cents to the order.
All items will be sent USPS first class mail with no special services or guarantees.
I will be opening a separate thread for ring-potted lamps. For those wanting ring-potted lamps for their Mag incan mods, I will need you to send me the lamps to be potted, as the WA lamps I have on hand are all reserved for TigerLight mod owners. Cost to ring-pot a lamp will be $5 per lamp, plus shipping.
Please post orders here, and note that I want to sell small quantities only as a service to CPFers. If you want more than half a dozen, spring for it and buy yourself a bag of 100 for $15 plus shipping from Newark electronics, or organize a Group Buy /ubbthreads/images/graemlins/grin.gif.
Thanks everyone.
*CLOSED*
image removed
image removed
Thanks everyone.
*CLOSED*
