[ QUOTE ]
balrog said:
Some people have U binned Luxeon IIIs. I'm not sure if this was the bin assigned from Lumileds or from independent measurements but these are almost unobtanium right now. Maybe the next generation from lumileds might be the equivalent of an XW0H /ubbthreads/images/graemlins/icon3.gif I sure hope so
[/ QUOTE ]
Maybe not X bin, but I'd say by this time next year U bin LIIIs will be the norm, and you might hear of the occasional V bin. X bin LIIIs will probably be the usual within 3 or 4 years, hopefully sooner. Remember that Lumileds and Nichia are sharing technology, and Nichia is due to start producing 60 lm/W 5mm LEDs next year. An X bin LIII would have an efficiency somewhat greater than that (actually 80.2 lm/W minimum going by the typical Vf of 3.42V @ 700 mA).
BTW, a Z bin would have an output range from 324 to 422 lumens. This should cover any possible LIII for quite a while (the high end of that represents a 176 lm/W efficiency, which we won't reach for at least a decade). We'll probably need a revised binning system once Lumileds starts mass producing 10 and 20 watt LEDs. A 20W, even at current efficiencies, will be well past the Z bin.
