[ QUOTE ]
JDELUNA said:
I know that these 2 lights are very similar, but from what I have read the 2L is a bit brighter with its LED, but with the XENON, the A2 is brighter and had better throw. My question is that what makes the A2 so much brighter and have better throw than the 2L. Techincally they both have 3 LED's surrounding a Xenon bulb so the reflector can only do so much for the throw, is the bulb on the A2 more better as in lumens ?? If so how much as I thought they were rated about the same ?? Thanks for any info. God Bless. /ubbthreads/images/graemlins/smile.gif
[/ QUOTE ]
1st off DELUNA, disclaimer: I frequently disagree with reigning 'so called Hot-wire' guru's, especially what I would call enthusiastic hyperbole from js (of the monster TigerLight mod's fame) /ubbthreads/images/graemlins/touche.gif . Sure it's fine for people to get excited about something they like, but you have to understand that their enthusiasm may not translate to anything remotely how you might perceive a light. Personally, I have very bad eyesight, and for whatever reason...want/need more than the puny 50 lumens output of the A2. Sure as Size15's points out, you can harness to a certain extent, the meager output of 50 lumens, and get a weak spot of light to throw a good distance. But a weak spot of light does no good for someone who wants to see clearly at distance. Same could be said for more of a flood at a shorter distance.
Let me link you to some instructive beamshots done by Kiessling to show you just how much beam patterns affect what you can perceive
Gargantuan Real Life Shootout - PICS NOW ONLINE
A2's just cost way too much for what they do
not do. If they had included a higher outputting lamp assembly, this would be a nice light. I will agree the quality is high, and size is fairly small; but we have other lights here on CPF that are of similar quality and size, that don't cost $180. Does wimpy 50 lumens constant output of light justify the hefty premium of the A2? Not IMHO. Probably good ideal to get yourself an insurance policy to cover loss of these expensive lights.
Still, if you use Li-Ion rechargeable (I hate using throw away batteries, and many CPF members and SureFire itself, are not very environmentally conscious) batteries you can get a nice relatively flat discharge curve where the voltage does not drop as rapidly as other battery chemistries. Since Li-Ion are at 3.7v nominally, an A2 that could use /ubbthreads/images/graemlins/frown.gif , 2 R123's instead of throw-away CR123's, would be able to run 7.2v bulbs, or better still, 6v bulbs using a higher voltage regulator circuit (this would require additional circuitry for the LED's, but so what; the A2 already costs $180, there is enough profit built into it already).
In a class by itself, by virtue of regulation or high price? Not very impressive class to me, 50 meager lumens. I put a similar regulated circuit into my M*g2D, which has a much larger/longer throwing reflector and very useful beam changing
focus/defocus mechanism. The 3.6v bulbs supplied with the Willie Hunt/Skip Langan 8AA-2D regulated adapter are rather disappointing in the yellow light they produce. Constant output, low output yellow light; hardly worthy of any hyperbole from me, sorry /ubbthreads/images/graemlins/frown.gif
So the A2 was supposedly purpose built to light up the outside of a Boeing 747, for inspection purposes? Huh, if my life depends on a quick outside inspection of a jumbo-jet I would prefer someone walk around the plane with a 2000+ lumens outputting, adjustable focus/defocus 35W HID like the X990, slung over their shoulder. 50 lumens of narrow light, does not give me much confidence, sorry /ubbthreads/images/graemlins/frown.gif
You can read my comments, and others ranting of praise on this light in js's A2 thread:
Thinking of getting a SF A2. Opinions?
Oh yeah, and another counterpoint on the 'greatness' of engineering (more hyperbole???) in the similar voltage regulation circuit, employed in this light by Surefire engineer Willie Hunt:
Regulated 8AA-2D adapter-W.Hunt/S.Langan
Soft start circuit - please explain...
[ QUOTE ]
Doug S said:
BTW, while it seems intuitively obvious that soft starting an incandescent lamp would extend it's life, the actual benefit is negligible. I personally have been involved in spending many $K in R&D on this very issue as well a many $K in patent attorney services. We were surprised to demonstrate that the benefit simply isn't there. BTW, there are many patents issued for apparati to accomplish incandescent lamp soft start.
[/ QUOTE ]
That being said, I'll agree with others; the SL TT2 is just too fat to carry in the pocket.
