LED VS Incandescent re: Flux, Lux & Temperture/color
Let's define Flux as lumens out front end, Lux as intensity of beam and temperture as color or tint of beam.
thanks to Don for pointing out Flux VS Lux combined with temperture of light issue in another thread here
When one gets exposed to LED lights that are in Surefire M6 Lola class output. At that starting point, one can start to eliminate Flux comparison issues.
What has been pointed before, but not highlighted is throw without Flux only gives you a tiny spot of light on a far away target. Petty worthless IMHO.
I'll get flamed for this, but my experience indicates a 5watt equiped with correct reflector will throw equal to a 3watt, but with greater flux. There is no subsitute for horsepower!
to get to Surefire M6 Lola levels of lumens with LED. One can either drive one overachieving Xbin at 1.5amps levels or use at min a tri-lux (Ubins) at 1amp per lux.
One Xbin 5watt with say 2in reflector will outthrow three SO20 reflectors over Ubins. Flux output will both be simular.
temperture or color of light allowing one to overcome ambient light is personal preferance. When enough flux is delivered to target, I perfer more nutral color of LED VS incand. I can always see better with LED.
I've heard from most folks they can see better with incand. Have always wondered if this is due to flux delivered VS temperture. As it's easy to get 250+ lumen incand VS pretty hard to get 250+ lumen LED.
your thoughts....
your thoughts....
