I'm going to say that I've actually accomplished soldering a surface mount chip to a circuit board.
Dat2zip gave me a plain board to practice with and I soldered a Maxim MicroMax surface mount chip to it. I just soldered one side and then bent it up to inspect. The joints look good under a magnifying glass. Here's how I did it:
1. Rig up a magnifying glass.
2. Clip chip to board with paper clip.
3. Wipe on a little flux.
4. Use big dirty soldering iron to slop on a big drop of solder and make a sticky mess.
5. Clean off soldering iron and use solder wick to absorb excess solder.
6. Clean off extra flux with poking tools.
I couldn't believe it. All the joints were clean and there was no bridging. I bent up the chip since it was only soldered on one side and all the joints held tight with light passing through in between each leg.
Time to get a couple SurfBoards for more practice, but it can be done with simple tools.
