this is so complex an issue. that its hard to explain all the way around, so i will avoid trying to agree with all that was said above, even though most of it is acurate, its dependant on the charger type, rate, etc etc. meaning it could be 100% wrong in different situations.
everything is right in the context it is used, everything becomes horribly wrong if its used out of the context it was intended. which ALWAYS happens when people like me dont know what the heck you guys are talking about /ubbthreads/images/graemlins/smile.gif (newbies)
EX: overcharge ni-?? PACK to balance the cells at 4A , BAD news.
(am i being anally critical, when most chargers out there only work one way? mabey)
and that is the problem , dependant.
if you are charging to a specific voltage, then parellel charging is PERFECT, if your just tossing a specific ammount of current in then stopping, then it sucks.
see dependant.
if you keep a specific voltage on a set of parellel cells of any type on till each of them reaches that voltage point, the current is balanced out till each it topped off the same.
this works EXCELLENT for li-ions.
AND you completly balance out the top charge for all of the cells, what could be BETTER? nothing, but one expert says its a disaster, because of the METHOD of charge.
so now read over that again, what METHOD did i say this would be effective for? Huge difference here in how its done.
rebalancing a Series pack of Ni-??? is done by slow overcharge, OR completly seperating the cells as individuals and cycleing them seperatly.
you can NOT properly rebalance the cells in a ni-??? pack by blasting them, and stopping when some arbitrary high voltage is reached, when some arbatrary current is input. there will always be some cell in the series pack that will not be at full charge.
rebalance is hugely important, because it reduces reverse charge
what we have here is assumptions made based on the charging TYPE, or based on one or anothers manufactures method for charging.
it becomes nessisary to think more LOGICALLY, so you can analize WHAT is occuring on the METHOD your using.
1) in series each does get the same current, but does that mean that each will charge the same . . . NO. but very close if they were all discharged the same.
2) in parellel they recieve current based on the state of charge (voltage differential) a lower voltage (charged) one is likely to get more current passing through it. but depending on how the charge is stopped, the low one might still be low when your done.
3) every cell in every battery pack is different in some small way, total capacity, it charged voltage, energy to storage abilility, even discharge rate.
4) cell imbalance sucks it is what does (series) PACKS in more than anything
5) any type of overcharge to ni-??? cells should only be done SLOWLY , so if you use this method to rebalance the few that have not reached the top, dont blast it then.
6) seperate PACKS to singles or parellel sets every once in a blue moon to rebalance or cycle rebalance them.
7) li-ion SINGLE cell protection will cut off series charging to the other cell, so you can not get full charge on single cell protection without single cell charge SEE #6
8) li-ion PACK protection curcuits VARY, some of them the batteries act like single units (see7) and some Properly top off the lesser batteries in the pack before cutting the entire set off. cant guess which packs DIE
i hope this explains WHY there is 101 ways that its right and wrong to do things, because there is also 101 curcuits, and chargers , batteries, and ways they get applied, that make any outright single answer on HOW, neer impossible.
