Gambit
- Joined
- Dec 17, 2004
- Messages
- 8
Dr. Nick: Hey everybody!
Is it possible to edit two files, that are under two different XP users, at once? Or, if it's possible to synchronize the two files so that when one is changed so is the other?
To be specific, I'm talking about the info.htm file found in AIM's (AOL Instant Messenger) folders. I have one AIM screenname that I use on two different XP users. I find that when I change my AIM profile/Buddy Info under one XP user, it does not change under the other XP user. I understand that it does not change because the two XP users have separate info.htm files but I was wondering if it's possible to sync the two info.htm files so that when one is changed so is the other? Or, if it's possible, to just edit both info.htm's at the same time? Either way is good.
The AIM files in question are located in C:\Documents and Settings\****\Application Data\Aim\sdfklhj\AIM_SN and in C:\Documents and Settings\****\Application Data\Aim\djfhugh\AIM_SN2.
Thanks a lot!
Thanks a lot!
