goldserve
So this is what i've done when I got the JIL DD this morning. Pictures are worth a thousand words =P
I need all the help and brain power from you guys!
As seen in the pictures, there is not enough room to fit the FLuPIC inside and things are bulging out on both ends. I have a few hunches on how to fix this but you guys may come up with more creative solutions.
As you can see, the reflector does not sit on the flashlight body.
As you can see, the UCL lens is 2mm thick. I can opt to go for a 18mm x 1mm mineral glass lense (If someone wants to help and send me some QUICK, I'll give them a free FLuPIC board) and the reflector cap should cover the unslightly orange o-ring.
FluPIC sandwhich module. I can make my own PCB for the emitter and use 0.8mm instead of 1.6mm thickness as well. If someone has a shop that can make me emitter boards quick, please contact me!!!
Bottom of FLuPIC module. Notice the o-ring in place. I use this to lower the flupic module into the battery compartment but not too much. That is how I squeezed some room from the other end of the light.
This is how it would look if i used thinner mineral glass lense. I can also take out the o-ring and it would not be dunkable anymore.
If anyone has anything they can help me with, please post here!
Update 10/04/2004:
I have got everything figured out and waiting for some new PCBs made. I should get them sometime next week so watch out for updates!
Here is a picture of everything assembled and looking purdy =P
DIY KIT:
-1 x 0.6" emitter board (without led)
-1 x soldered FLuPIC board
-1 x metal spacer ring
-2 x metal posts to connect FLuPIC and emitter
Estimated cost $35.
Fully Assembled Drop In:
-Everything in the DIY KIT but soldered
-Choice of luxeon led (TWOH, TYOH, UYOK, TWOJ)
Estimated cost $40 + price of lux.
Update 10/11/2004:
tvodrd machined 15 or so aluminum rings for this project. See below for pictures!
Update 10/20/2004:
Boards are in, pictures to follow soon. Stay tuned for ordering instructions!
Update 10/04/2004:
DIY KIT:
Estimated cost $35.
Update 10/11/2004:
Update 10/20/2004:
