Hi Guys,
Two is one; one is none.
I have been giving a lot of consideration to backup/secondary lights lately. One of the questions that has to be dealt with in choosing a backup light is what it should do. Should it be an identical redundant copy of my primary EDC light? Should it be a battery container for the EDC that emits light if the primary fails? Should it be something that just gets you out of wherever and back to your spares? Should it have a fundamentally different function than the primary light?
Obviously the answer to those depends upon what you are doing. Combat duty in Iraq might dictate two duplicate and substantial lights. A summer evening trip to the theater might dictate that your spare is very small. Below are the kinds of things I am envisioning.
High stress situations. If you are doing any skill-intensive job in a hostile environment you probably want a light that is second nature to use and reliable. And you probably want to grab the same thing if you lose your primary light for any reason. Two SureFire G2s would be an example. If one bulb fails, you grab light #2 and get back to business with 100% of original function.
Travelling light. You have your primary light, but maybe it isn't essential to have that level of function in your backup light. Say you are going along in your everyday (everynight) travels with your regulated flashlight and -poof- the battery goes dead. Maybe all you really need is the bare minimum to keep going. This could be my current carry: McLuxIII-PD and a Photon Freedom.
Battery carrier. Maybe your primary light source is reliable (quality LED light) but you might need spare batteries. I got a SureFire L4 that was supposed to fill that role for my L2. I generally use the low setting on the L2. The L4 makes a small (but expensive) battery carrier that allows me to keep going with my L2's two brightness levels. And the L4 will work on its own if the L2 is KIA.
Something different. Some lights just don't do some jobs. I love my little PD, but doing a quick-draw for use as a defensive tool? That ain't happenin' -- It's too short and too smooth, and I'm not sure pressing through a dim level to get to bright is the best thing for stunning someone's retinas. But I still want the low level for normal use. Maybe a Night-Ops Gladius would be a good backup then. Or a red Gerber Infinity, if I am more interested in doing a little stargazing, not attracting attention, or general dark-adapted vision preservation.
What do you guys think?
What kinds of redundant light do you carry (if any), and most of all, why did you choose that option?
Scott
Scott
